Results 2,261 to 2,269 of 2269
August 10th, 2024 03:26 PM #2261
August 10th, 2024 03:27 PM #2262
Well, can't do that without voiding the warranty. You can only tamper with the seal after that. However, the damage is probably done by then. Batteries of old had exposed inter-cell conductors so you're able to at least test the voltage on the individual cells.
Yeah, I get that. But I am doing this to prove to myself whether or not this battery will last beyond that. I am shooting for 3-4 years, at the least. Let's see if I'll get anywhere near that if I pampered it.
August 10th, 2024 03:55 PM #2263
Yes it is. And it often happens in the most inopportune time.
So even if you decide to change it before the expected end-of-life, you're not even sure when that would be. And so you adjust by changing it way earlier, and then you realize that you're not getting your money's worth by doing that.
As a side note, I stopped using Seagate HDDs more than a decade ago because their failure mode, as per my own experience, is 4/5 times, abrupt. It was working with no signs of imminent failure one day, but would suddenly not show up on your computer the next time.
WD on the other hand, again as per my own experience, fails a bit more gracefully, giving you enough time to move your files or take preemptive actions. Though I backup all my PCs now so this has become less of an issue. Sorry for the OT.
- Feb 2014
- 2,658
August 10th, 2024 07:27 PM #2264
yeah by the time the warranty expires there's definitely some imbalance and low electrolyte going on, thereby ensuring that it won't live a long lifeit's a bit of a scam really.
best thing to do is to throw the warranty out and start doing the interventions early like within the first year. if the CCA readings are healthy then there's no reason to believe that the battery will fail prematurely so go ahead and void it
- 53,883
August 10th, 2024 09:37 PM #2265years ago, we replaced only the bad cells, leaving the healthier cells intact.
after a while, the so-called healthier cells would die.
we concluded that it ain't worth the piecemeal replacement.
doble or triple pagod mo, for a measely tipid...
we have to learn to price our time and our pagod and effort.Last edited by dr. d; August 10th, 2024 at 09:42 PM.
- 53,883
August 10th, 2024 09:40 PM #2266
August 10th, 2024 11:34 PM #2267
Amaron is just way better then Motolite for the same price. Ang layo ng performance and longevity. I won't use Motolite again unless out of necessity.
Fasten your seatbelt! Or else...Driven To Thrill!
- Jan 2007
- 2,452
August 11th, 2024 04:25 AM #2268There does seem to be an ongoing smear campaign against Amaron. If you look at FB there's going to be some random off-topic reply that hints at its... explosive nature even when it's not germane to the discussion.
August 11th, 2024 08:58 AM #2269
I think it's the excessive buildup of hydrogen gas is what caused these batteries to potentially explode. From what I am seeing, this seems to happen, more often than not, near the battery's end of life. This is usually when some of the electrolytes have evaporated, leaving parts of the lead plates exposed. This condition apparently accelerates electrolysis in that cell, producing more gas than normal. If there was truly a defect on Amaron batteries, it could be the way the valves were designed. It is possible that they are too restrictive in letting gas escape, hence, when the gas buildup is too much and has nowhere to go, it gets catastrophic.
It is then prudent to check the water level in your battery, maintenance-free or otherwise, to make sure that all plates are sufficiently submerged in electrolyte solution. I'll do the same on my current Motolite around when the warranty expires, 8 months from now.
To Amaron's credit, there's probably only 2 or 3 such failures that's been shared online. I could be wrong but I haven't heard of repeats in at least the last few years. Maybe they have quietly corrected the issue?
