Results 131 to 140 of 385
July 10th, 2018 04:10 PM #131
so far so good. when installed the sensors record 1psi higher than my trusted analog tire gauge. driving around taguig to bgc for a few minutes in slow traffic, umakyat ng 1psi mga tires with the front tires going up first.
the temperature sensors are a little too sensitive for my taste pero it means it is accurate. initially sa parking before leaving, one tire was warmer by 1c. which might be true kasi yun yung naaarawan. going to bgc, the two passenger side tires are always 1-2c higher given sila yung side ng araw. akyat-baba ng akyat-baba by 1-4c every few seconds depending on how i drive. pero checking sa covered parking kanina, nagpantay na silang lahat.
yung monitor turns off after no motion for a few minutes. pag naka-detect ng motion (ex, door is opened or tinapik mo yung sasakyan), nag-oon yung monitor. never plugged it in. relied on solar power and so far palagi naman full bar yung battery indicator. sana tumagal yung battery sa sensor.
user's manual is very hard to understand. ang liit ng sulat, broken english pa. kinapa ko na lang kung paano isetup. may 2 parts lang na di ko ma-gets regarding tire pairing and kapag nag-rotate ka ng tires (might as well just rotate the sensors para di nakakalito).
di naman madaling nakawin. unless you have that wrench that comes with it or pipilitin mo, which in case, masisira mo yung sensor or yung pito.
only concern ko now: is it heavy enough to affect tire balance? sana in the future they can make it smaller para less conspicuous.
- Jan 2013
- 1,851
July 10th, 2018 08:48 PM #132
- Oct 2012
- 4,851
July 11th, 2018 02:17 AM #133
- Oct 2012
- 4,851
July 11th, 2018 02:21 AM #134
- Jan 2013
- 1,851
July 11th, 2018 09:43 AM #135
July 11th, 2018 10:30 AM #136
- Aug 2014
- 126
July 11th, 2018 06:25 PM #137
- Jan 2013
- 1,851
July 11th, 2018 08:13 PM #138
- Oct 2012
- 4,851
July 12th, 2018 01:33 AM #139Yes pero hindi nila basta2 magagamit kasi need din ang receiver... it will just somehow make harder for magnanakaw to steal the tire cap... kaya advise ko din park sa safe na lugar...
- Jul 2018
- 1
July 21st, 2018 01:35 PM #140Hi. New to the forums here. I have a set of stock TPMS from my Mitsubishi Pajero 2014. After tire rotation at a gas station, the TPMS monitor onscreen went blank as in "--.--" in all tires. How can I reset or recalibrate the TPMS? Also, I think its brand is AVT.
Tesla Philippines
