Results 2,451 to 2,460 of 3510
- Sep 2016
- 126
November 30th, 2016 09:39 AM #2451If you're going to use Handbrake, then don't use Windows Movie Maker to edit the scenes! WMM maxes its outputs to 720p, and all of their settings are "lossy" so by the time you are transcoding with Handbrake, may konting degradation na ang source. Indeed, kung gagamit ka lang ng WMM, then use its built-in transcoding settings. I use the "Facebook" settings because it outputs clear video at 720p with negligible artifacts and a much lower filesize.
If you want to use Handbrake, then use Avidemux to edit the video and choose "copy" for both video and audio output, so that the file output will not be transcoded during editing.
Or you can forget Handbrake and use Avidemux directly to transcode the video after editing. Avidemux, like Handbrake, uses ffmpeg, and you can configure Avidemux to output similarly to Handbrake. Medyo matrabaho lang i-configure but it can be done.
November 30th, 2016 11:15 AM #2452
- Nov 2016
- 11
- Mar 2014
- 291
November 30th, 2016 06:34 PM #2454
- Aug 2014
- 126
December 1st, 2016 04:30 PM #2455Hi, question sa mga transcend users. Bought my DrivePro 520 few months ago (more or less 3 months), ngayon yung experience ko is naghahang sya randomly, medyo hassle kasi malaki posibility na mabangga ako tapos hindi pala nagrerecord yung dashcam ko. May naka experience na ba neto? And saan pwede ipadala for repairs? Bought my DP520 from PCWORX. thank you.
- Aug 2012
- 2,767
December 1st, 2016 04:48 PM #2456
- Aug 2008
- 498
December 1st, 2016 10:22 PM #2458
- Mar 2014
- 901
December 2nd, 2016 01:25 AM #2459As dreamur said. Check and review your settings. And check your micro SD memory card if compatible to the device. Mostly they recommend Class 10 memory card. Ang default setting yata sa loop recording kadalasan sa mga dash cam ay 3mins.
Have you tried to reformat the micro SD card on the device since you first insert or installed in it?
Kung nagha-hang pa rin.
Have you tried resetting it? Or restore to system default setting? Then check or trial it out again kung mag-hang pa rin after resetting. Kung mag-hang pa rin palagi, bring it back sa store where you bought it for warranty service repairs.
Sent from my Up Snap using Tapatalk
- Aug 2014
- 126
December 2nd, 2016 12:35 PM #2460
Tesla Philippines
