Page 242 of 351 FirstFirst ... 142192232238239240241242243244245246252292342 ... LastLast
Results 2,411 to 2,420 of 3510
    Nov 2007
    #2411
    Quote Originally Posted by logbi77 View Post
    Curious question lang, are there dashcams in the market na ang FoV eh 120 degree or less? Usually kasi ang mga dashcams sa market eh 130 degrees pataas na ang inilalabas.
    The G1W has a 120 degree FOV
    Oct 2016
    #2412
    Quote Originally Posted by JJB View Post
    Thanks. Will take note kung meron pang ibang model.
    Aug 2012
    #2413
    Curious, why you need narrow FoV?
    Hindi ba wider FoV is better so you capture more area in the video?
    Sent from my D5833 using Tapatalk
    Oct 2016
    #2414
    Quote Originally Posted by red_one View Post
    Capturing more area is the main positive of a wider FoV but on the flipside, objects look farther than in reality. I noticed this when I reviewed the footages from the DP200, which has a really wide 160 degree FoV lens. It's not really a bad thing, but a narrower lens gives an impression of the objects distance closer to reality.
    This is just a personal preference though. I'm just hoping that dashcam manufacturers will give a selectable/adjustable FoV setting in the future so users will have a choice based on their preferred FoV, like some action cameras do para everybody happy. :D
    Oct 2009
    #2415
    You might want to try the dual lenses it has a reduced FOV compared to DP200
    _/_/_/The more things are forbidden.. The more popular they become. _/_/_/
    Oct 2016
    #2416
    Quote Originally Posted by forceG View Post
    I'm currently using the Soocoo C30 action cam at the front with its 110 degree angle software setting in the meantime, while putting the DP200 at the back. Will look at these dual lenses. Thanks!
    Feb 2015
    #2417
    Yup, ok na yan. Yung iba nga generic brand micro SD lang gamit.
    Thanks sir. Installed na and nagamit ko na ppupunta divisoria. So far so good. Transfer of files through wifi is at 3mbps. 3min clip is at 350mb on 1080p/30fps setting. Ang kulit nga talaga ng adas. Kaya pala recommended nila to just turn it off.
    #2418
    Guys, sino naka yi dashcam dito? Anong gamit nyong mount to attach it sa rearview mirror? Tried matching the sjcam bike mount but it wouldn't fit. Thanks
    Sent from my MI 3W using Tsikot Forums mobile app
    Feb 2016
    #2419
    Sa lazada ata meron sir. Dashcam holder.. Pero ako ang gamit ko pa din ay yung stock.
    Sent from my Starmobile PLAY Click using Tsikot Forums mobile app
    Feb 2015
    #2420
    Quote Originally Posted by sphinxz View Post
    Sa olx sir may nagbebenta for 600 pesos.
Blackbox DVR/Dashcam
