Page 19 of 139 FirstFirst ... 91516171819202122232969119 ... LastLast
Results 181 to 190 of 1387
    Mar 2012
    #181
    Stage 2 nga from Redline, NHK bulbs. Q5 projectors.
    I'm not saying there aren't any HID retrofits stronger than LEDs. I'm saying my 20k stage 2 retrofit is not stronger than my stock LEDs. Retrofitters always market that even their stage 1 retrofits are stronger than LEDs. Again, my personal experience proves otherwise.
    Hindi lang clear ang cutoff ng LED, but the illumination both low beam and high beam is brighter than my retrofit.
    Then you should have put that on your reply sa comment ko. Yung first question kasi is asking if its led vs hid then you said na mas malakas ang oem kaysa naka retrofit na setup. I wasnt aware that the price is also being discussed I thought this is about performance.
    I'm with you na hindi tamang mag claim ang isang retrofitter na mas malakas ang stage 1 kaysa oem led but then again depende din kung anong gamit sa stage 1 ng retrofitter at ano ang specs ng naka oem led HL na kinkumpara ang retrofitted HL.
    May 2013
    #182
    Any feedback on Chroma Lights Lipa? I seem to see them on fb, quite a lot.
    #183
    Quote Originally Posted by D3nb3r View Post
    Yep I put that in my first post. ๐Ÿ˜‰
    Have a good day. ๐Ÿ˜Š
    Mar 2012
    #184
    Quote Originally Posted by bugoys View Post
    Wala ako experience sa kanila but parang ok naman yung set up nila. clean and neat. May mga custom jobs din silang ginawa. But this is a new player on retrofitting business sa pinas so medyo wala pang mga detailed feedbacks sa kanila if compare mo sa mga datihan na. Pag maraming shop mas maraming option ang mga tao and in some cases this would be good sa mga gusto magpa retrofit since marami na mga shop so pababaan ng prices. Pero ang trend ngayun baliktad, ang mga shop pataasan pa rin ng mga prices only one thing is common sa kanila, yung mga level of stages ng setup nila. so may option ka kung saan pasok budget mo.
    Mar 2012
    #185
    Its all good. Have a good one too
    Jun 2011
    #186
    Guys... Search nyo sa FB Ks led or keon sondra...
    LED bulb lang pero... mas malakas output sa HID..
    Kahit fogs lang palitan nyo malakas na...
    Got it for only 5.5k 13200lumens.. !!
    Kahit maulan clear pa din....
    Kung naka projector ka.. parang laser lights na...
    I compared it to my friend na naka HID RETRO.. MAS solid at malakas ang output ng ks sondra...
    Even my Club mates is telling me... mas gusto nila output ng Ks led kesa sa expensive HID retrofit worth 45 or 55k?
    Mar 2013
    #187
    I might try those KS LED bulbs
    Mar 2012
    #188
    Damn. Here we go again No offense but one of the purpose of this forum is to promote safety. Nakita ko yung FB page na sinasabi at grabe ang glare ng mga producst nila. Yung iba walang cut off yung iba meron cut off pero kita mo sa glare abot sa taas ng puno. Common guys, this is why led bars and HID is getting a bad rep. Be responsible.
    Jun 2011
    #189
    Paps... hindi glaring... at naka low beam ka lang...
    On high beam kahit halogen glaring na din... nasa headlight mo yan... wala yan sa LED bulb the led bulb is designed like there are two LED for high and low.... the low beam is position upwards. when you switch to low beam... the upper part LED lang will open... led it will reflect on the upper part of your headlight... when on high lower and upper part ng LED naman will turn on...
    Or if ang setting ng Headlight mo naka tingala...
    May i ask... naka HID retrofit ka ba?
    Jun 2011
    #190
    You said you check the page...
    You can see naman the output... mababa.. pag low beam.. pag high beam.. natural lang na mataas... ayun ang glaring... kahit HID retrofit pag naka high beam ka glaring
Planning on getting an HID retrofit
