Results 51 to 60 of 106
- Jul 2008
- 479
June 24th, 2013 11:21 AM #51sir kamusta buga ng High beams with the bsoch 85 watts? sakin kasi, ONB+ and parang naka focus masyado yung high beams ko tsaka 55 watts so not much brighter than the oem. I plan to replace this with bosch white halogens na 85 watts pero issue ko yung pagiging focused ng high beams. dba dapat medyo kalat ang buga ng high beams?
- Mar 2011
- 9
September 18th, 2013 08:08 PM #52Yung bosch 85W all weather on stock wirings ok pa rin. Throws long and illuminates wide (since this is the design of the reflector of the high beams. The high beams have a focused center and some surrounding cast off light. At 55W the cast offs are weak but at 85W it is more pronounced and lights up reflectorized signs not usually lit like EDSA overhead signanges and since yellow sya mas kita yung signs). If you plan to go 85W check your terminals muna kung kakayanin. Yes dapat mas kalat since you need to see farther and wider to see obstacles crossing or at the end of the road.... But it still depends on the reflector of your high beams...
Hope this helps out..
November 3rd, 2013 03:12 PM #53
November 3rd, 2013 03:58 PM #54
December 19th, 2013 12:07 PM #55
osram has 2800k while bosch has 2900k.
does it mean that osram all weather is yellower than bosch?
December 29th, 2013 02:09 PM #56
Ace is selling bosch all weather plus, 60/55w. what is peculiar about this is its bluish bulb. beside it is bosch star bright with 3200k also 60/55w. it has bluish bulb too. according to bosch' site, AW is yellowish.
i guess Ace wants to dispose this asap that's why they are selling it for P500 only. while star bright cost more than P900.Last edited by trucker111; December 29th, 2013 at 02:16 PM.
January 2nd, 2014 02:33 PM #59
January 2nd, 2014 02:33 PM #60
also had my car's HID removed last weekend.
got flosser bulbs (made in germany) for 350 pesos each.... 100/80w + relays + ceramic sockets.
Tesla Philippines
