Page 5 of 11 FirstFirst 123456789 ... LastLast
Results 41 to 50 of 106
    #41
    hi mga sir currently naka hid ako and balak ko bumalik sa stock using osram all weather kailangan ko pa ba palitan yung sockets and magpa rewire?
    #42
    Quote Originally Posted by lemonblu View Post
    basta ba yung ikakabit mo na osram halogens same wattage ng OEM bulbs mo, no need for re-wire or palit sockets.
    May 2013
    #43
    yun bosch or osram all weather ba, direct drop in replacement sa civic (dimension)? sabi kasi nung kausap ko sa banawe, ipa all weather ko na daw. bumbilya lang daw papalitan oks na. hindi ne kelangan ng kit. im planning to change bulbs kasi madilaw na sya. kung papalitan ko nito, worry ko baka sabog ang buga ng ilaw.
    #44
    dati narva all weather ako... okey kahit sa baguio at halos 5 yrs ang itinagal
    bosch ang ipinalalit ko na all weather after mapundi yung isa dahil wala akong mahanap na narva rin... malabo sa gabi lalung lalo na pag umuulan
    ngayon osram all season ang ipinalit ko... parang narva din ang buga niya mas okey kesa bosch
    Mar 2011
    #45
    Hi all,
    I currently have both BOSCH all weather H7 85W and OSRAM H7 55W all weather installed on my santa fe. The OSRAM's light is yellowish white but mas malakas sa stock 55W ko and is being used as a primary low beam (better results in rain) on projector type lens. The BOSCH naman is yellow (parang H4 bulb na may yellow glass cap) but since its 85W and is used for high-beam it does its job well lighting up farther and wider than the stock. The BOSCH sold for P750 but the guy said its made in korea, unlike OSRAM daw germany... I have been using it for a month so far ok naman. I had H4 100/90W FLOSSER golds before and it had yellow purple light paired with clear 100w H1's on hi-beams awsome...
    Aug 2010
    #46
    do you need to install relay when upgrading to all weather bulbs coming from stock?
    does the stock bulbs have relay?
    #47
    Quote Originally Posted by trucker111 View Post
    Depends on the wattage. If it's 55w, then you don't need to install a relay.
    Nov 2011
    #48
    ako i like to buy a philips XV (priority) ot s Osram NB+, kaso dami daw fake nito
    #49
    Kahit naman PXV madaming fake. You just have to check the quality parin to be sure. I bought ONB+ so far ok naman. Mas maliwanag talaga compared to stock.
    Jun 2012
    #50
    Quote Originally Posted by jresperanza View Post
    We have genuine Philips XV and OSRAM NB+.
    Yun nga lang sa Cavite ang shop namin but we can meet you at MOA or Petron Macapagal pag meron lalakad sa amin pa Manila. We can also ship to you via LBC kung nasa ibang cites outside metro kayo. Kayo magbabayad ng pa-LBC.
    For XV we have H4, H7, H11 in stock. HB3 and HB4 should be available next month.
    For NB+ we only have H4 but other bases should be available next month too.
    We also have available genuine Philips D2S.
    If interested PM me or text/call 0919 991 7769. Please ask for Joy.
Bosch all weather or Osram all weather
