Page 254 of 307 FirstFirst ... 154204244250251252253254255256257258264304 ... LastLast
Results 2,531 to 2,540 of 3070
    Aug 2009
    #2531
    Quote Originally Posted by Joke_Serious View Post
    goodmorning po newbie lang po sa sa car audio..hingi lang po sana ako advise mga sirs kung ano mas maganda ipares sa focal 165fx na amp between helix g4 at audison sr4..btw HU ko po pioneer AVH595BT..TIA po
    I think either of the 2 ok lang naman but marami akong nakikita na helix amp ang combo para sa focal expert.
    Aug 2017
    #2532
    Quote Originally Posted by Sleepcare View Post
    Thank you sir helix na lang talaga siguro ako at mas mababa ang price nya compare kay audison..
    Nov 2015
    #2533
    how bout focal's new fpx line..4.400sq?
    Aug 2009
    #2534
    Quote Originally Posted by ikloyputograpi View Post
    Sa totoo lang boss never pa ako nakakita ng focal seps na powered by focal amps. Usually audison/helix/rockford ang terno.
    Aug 2017
    #2535
    Highly recommended po kasi ng installer ko (simplesound) sir ang helix or audison..mas maganda daw po kasi ipair ang focal seps sa dalawa na yan sir..tnx sa mga inputs sir
    Nov 2015
    #2536
    if in any case i would want to hook up a pair of coaxials with an amplifier, how many channels do i need? is it 4ch also?
    a pair for the woofer and a pair for the tweeters? is this how it works?, complete newbie regarding audio setups, i just don't want to end up paying when its not needed.
    say for example i would want to install a PC 165F a Focal Expert Coaxial having nom power of 70w RMS, with an impedance of 4 ohms. and as per what i've read at Crutchfield, amp should range between 75%-150% of what the speakers RMS is. so tentatively it will be 55w-105w range. so approximately a Helix G4 having * 4 Ohms 4 x 80 will be satisfactory right?..
    this (car audio) is just rocket science for me, no idea from the beginning, awaiting for your inputs guys, thanks in advance.
    Nov 2015
    #2537
    i thought so too, majority of the focal seps are being paired with helix or audisons. i have only seen some post twice from timsaudiogarage being a full focal setup (seps with fpx amps), but then again, so you were saying focal fpx's line doesn't blend well with its speakers?
    probably, its quite confusing having built their (focal) own amps but doesn't juice well with their speakers, or i might be wrong, maybe financial constraint is also being a factor that's why we don't usually see a focal seps and an amplifier set? how much does a helix g4 and g1 cost by the way? i always see these combos from simplesound.
    Aug 2017
    #2538
    bukas pa po iinstall ni sir jonz ang unit sir..update lang po ako after..
    Nov 2015
    #2539
    is it an integration install? what is your proposed setup btw, if you dont mind if i ask?
    how many days would you think they could finish the installation?
    hoping you would share your setup with pics here at tsikot.
    Aug 2017
    #2540
    amps lang po ang pinalagay ko kanina sir..audison po ang pinalagay ko tapos ginawang full active na lang po ni jonz ang focal 165f seps ko sir..malinis na nga po ang tunog hehehe heto na po set up ko ngayon sir HU - pioneer avh 595bt, focal 165f full active seps, audison sr4 amps at focal bp20 bomba active sub..NOTE*** di ko po isahang bili yan sir one at a time lang pero nabuo din sa awa ng Diyos
audio set-up for beginners [continued]
