Results 21 to 30 of 49
- Nov 2019
- 1,239
July 22nd, 2024 11:21 AM #21Good to know po.
Will try this at home, due na for wash yung car.
Masyado maulan kaya minsan lagi ko pinopostpone carwash.
Pero sa ganito katagal hindi na carwash, raining or not will proceed.
Parang sinumpa na ata ako na everytime mag carwash ako, umuulan palagi sa lugar namin.
July 22nd, 2024 11:48 AM #22
That's impressive, *Vodka.
Do you still have to wipe the car after applying the foam to free up more stubborn dirt before rinsing it?
- Nov 2019
- 1,239
July 22nd, 2024 12:02 PM #23
- Feb 2014
- 2,658
July 22nd, 2024 05:32 PM #24
July 22nd, 2024 06:16 PM #25
I ordered this... haven't tried it yet. Still waiting for the foam sprayer.
- Nov 2019
- 1,239
July 22nd, 2024 06:54 PM #26Yung walang wax na shampoo sana.
I apply wax separately using a specific wax product.
Also, this is the pressure washer that I am using at home, yung Orange na HPB 302.
Bought 3 yrs ago, so far OK pa naman.
https://s.shopee.ph/8f8BFZtaGu
July 23rd, 2024 10:29 AM #27
My foam sprayer arrived last night and I got to try it out. I haven't dialed down the ideal solution ratio yet but it does work at the recommended 1:9.
I initially did a test clean on a single panel but decided to expand it to the rest of the car.... Reason being; the car is pearl white and cleaning just one panel was a bad idea.... colors no longer match.So I finished off the 1.5L solution to cover the front, hood, doors, quarter panels, all four tires, and the tail gate. I skipped the roof and all the windows.
Dirt appears to glide off easily with light wiping using a mitt. And since it was already 9PM, I didn't thought it was right to disturb the neighbors and so I skipped the pressure washer and instead used the balde and tabo to rinse. The solution came off with the grime pretty easily.
I'll give it a proper go when the sun comes out. But I can already tell that I might be better off buying the bottle attachment for our pressure washer.... faster dispensing and wider coverage.
- May 2007
- 275
July 23rd, 2024 10:59 AM #28
- Feb 2014
- 2,658
July 23rd, 2024 02:39 PM #29
https://www.lazada.com.ph/products/i...434253540.html
i also ordered a swivel connector for even more flexiblity
- Feb 2014
- 2,658
July 23rd, 2024 02:52 PM #30
this is 1:4 mtx shampoo. btw there's also a "high foam" shampoo from cochemax, might try it out next time...
yeah you're probably better off w/ this setup. sorry for not demo'ing it earlier haha, coz i used to pair it w/ my 18v washer which is a lot weaker so didn't generate good foam
btw there's another upgrade to these cheap cannons, there's this 3-layer upgrade to the metal foam inside. you might wanna try it out if you go this route
Tesla Philippines
