Page 5 of 5 FirstFirst 12345
Results 41 to 49 of 49
    #41
    Quote Originally Posted by Miles_on View Post
    Simple lang naman gawin kasi ang usual na PMS procedures (change oil, tune up, etc.)
    I wonder how that will change when we switch over to hybrid engines and electric vehicles in the future though...
    Palagay ko matagal-tagal pa naman ang lifespan ng mga internal combustion engines though, lalo na dito sa 3rd world.
    Anyone here remember how LPG powered cars & LPG stations fared just a few years back? People hated them (including the taxi drivers themselves).
    according to some writers, EVs should be simpler, as electric propulsion systems have less moving parts the ICEs.
    "... kuya! ilabas mo yung ancient de-tubo nating VTVM ni papa...!"
    i-P-PMS ko si kotse.
    Sep 2021
    #42
    Sobrang OT na tayo (branching out from the engine wash topic though)
    but what is VTVM?
    Feb 2014
    #43
    dumating na yung cochemax. walang beading effect yung built-in "wax". also the foam isn't as good as MTX should've gotten the high foam version instead. cochemax is an ok brand. their degreaser is pretty good
    #44
    but what is VTVM?
    vacuum tube voltmeter.
    in its day, it was the professional tool for electronics folks.
    for everyday use, however, a cheap VOM (volt-ohm-milliammeter) costing less than 500 bucks will be fine.
    May 2007
    #45
    Quote Originally Posted by Vodka View Post
    https://www.lazada.com.ph/products/i...434253540.html
    i also ordered a swivel connector for even more flexiblity
    Thanks bro. Need din pala palitan ang hose? kc de rokas ang short gun ... or may adaptor ba nabibili? I'm using Lotus ltpw1400x
    Feb 2014
    #46
    Quote Originally Posted by SRGuy View Post
    check the other sellers. there are short guns available in various connector types so just pick one that fits your existing hose. but apparently the most common type is the m22 x 15 i.e. the threaded part is 22mm while the smooth inner bore is 15mm inner diameter. you might want to migrate all your hardware to this size
    May 2007
    #47
    Peeps tanong naman - mas matibay ba yun yellow na pressure washer hose? planning to get one this coming 8.8 sale
    Feb 2014
    #48
    back in 2018 i purchased one of those yellow hoses, creston brand, at SM. leaked on first use
    i'm now using this cheap hose. P300 only. m22x15 on both ends. upgraded to quick disconnect on one end, swivel on the other
    May 2007
    #49
    Thanks bro. Bought this K variant connector -
    https://www.lazada.com.ph/products/m...21705140.html?
    kaso bumibitaw, hindi snag fit ang Lotus ltpw1400x hose, meron pala 2 klase ang quick connector: 4 and 5 series
    https://www.lazada.com.ph/products/p...40436239.html?
    Tama ba dapat ko bilin is 5 series? or better ba kung buy your same swivel connector tapos threaded hose? di nga lang quick-connect/disconnect ...
Mini car wash setup at home
