Page 1 of 5 12345 LastLast
Results 1 to 10 of 49
    Jan 2009
    What would be the minimum equipment list to have my own foamer?
    I would like to stay away from using buckets altogether.
    I already have a pressure washer, an air compressor (FWIW), etc.
    Jul 2013
    are you referring to the one used by local car wash shops?
    I suggest that you ask them kung saan nila binili yung gamit nila.
    I once found this sa Shopee, not sure if its the same thing kasi tinigil ko na yung "DIY Car Wash At Home" project ko
    https://shopee.ph/product/393825292/9664671950
    Project was cancelled since the "foam device" will take up space sa garage, plus, its not that nice to look at.
    Naisip ko din if Manual.
    https://www.lazada.com.ph/products/f...785733155.html
    pero as I said, the "project died na"
    last option for me was just to use shampoo from the Chemical Guys
    Jan 2009
    I'm thinking nga baka pwede na yung bottle attachments for pressure washers. Though, my pressure washer did not came with one.
    Jul 2013
    yes it works. yun din gamit ko right now
    pero its not as "foamy" as the one used by the kanto car wash.
    What's your pressure washer?
    Jul 2013
    Bosch EasyAquatak 100
    EasyAquatak 1 High-pressure Washer | Bosch DIY
    Feb 2024
    Foam cannon attachment for your pressure washer hose. You can find cheap ones on shopee.com
    The foam cannon alone will make washing way more enjoyable without buckets.
    Nov 2019
    Ano gamit nyo shampoo po?
    Im still looking for a shampoo that I can use para contactless na yung carwash ko.
    Tried before with MTX pero may nakita pa rin akong dumi na hindi natanggal.
    Kaya bumalik ako sa pag gamit ng wash mitt.
    Thanks! This and Karcher are what most tsikoteers have din ata
    Sent from my SM-M127F using Tapatalk
    Feb 2014
    interesting gadget. i think i wanna try
    i'm still looking for the best mini car wash setup first i got a 220v pressure washer. very powerful but the hoses are stiff, not very convenient
    then i got an 18v washer, a lot more convenient. also got a "foam cannon" for it but the foam is very watery so it runs down quickly
    so i tried those pump-up foam sprayers, foam quality is OK but needs a lot of manual pumping
Mini car wash setup at home
