Page 551 of 591 FirstFirst ... 451501541547548549550551552553554555561 ... LastLast
Results 5,501 to 5,510 of 5910
    Mar 2005
    #5501
    Nabasa ko sa autogeek online Griots Garage yung mas malakas followed by portercable then megs. Para sakin kung sa pads 2 Orange for defect removal, 2 white for polishing and 2 black for wax/sealant application.
    Yung 5.5 inch pad kit ng autogeek.
    http://www.autogeek.net/lake-country...d-pad-kit.html
    OT : May sobra pa kong 1 32oz na ONR 1k lang hehe baka may gusto snyo
    Jun 2010
    #5502
    Quote Originally Posted by bombitmd View Post
    Ang sakit ng katawan ko! Spent half the day cleaning the car yesterday.
    First I tried SwirlX for the millions of scratch marks and swirl marks. Ang masasabi ko lang, hindi kinayanan ng powers ko Kailagan talaga may machine sa dami; malamang ipa-BB ko muna and then maintain ko na lang...
    same here sir!!! wew sumakit kamay at braso sa application ng swirlx. Though may natira parin nga konting scratches at watermarks. Do you think sir nasa application lang talaga pagkukulang? Or do we need a more aggresive liquid? inaalala ko rin kasi clear coat, baka masyadong numipis
    May 2008
    #5503
    Quote Originally Posted by madkatz View Post
    The heat of the sun in our country is really really hot and i find it that if left to bake in the sun it actually stiffens a little so its better to let it dry in the shade, we did a test before and used a brand new MF towel and placed in under the sun for one whole day and when we got it back it was courser than it was brand new, so if you want your MF's to look and feel like they're new, first wash it properly with a strong enough detergent to do the job, i know that the instructions read that you only need to use mild detergents for washing MF's but when you use a collinite, how do you expect to remove a wax thats detergent proof? so thats why i first use a degreaser, or i scrub it thoroughly, and then once its clean, i then soak it for a few minutes in water and perla and then rinse before i let it air dry in the shade, the results? i heard some guys was surprised to see our MF towels still soft after more than 1 year of usage. but one odd thing is that for those really stubborn stains, i use warm water and it doesn't do anything to degrade the fibers it even helps to remove wax and polish residues.
    Wait, please do enlighten me on this. I've read on several online posts that using detergent soap can leave minute particles on the fibers that can cause paint marring later on. So right now, I'm using diluted liquid soap and warm water to clean my towels. So, would this degreaser + perla combination produce better results?
    Aug 2009
    #5504
    *rico_g: haha nice beading! thats some maintenance you made for it to still bead that nice, either that or the paint was well prepped to accept and bond the wax properly
    Aug 2009
    #5505
    To the two doctors who bought the OCW, OCW's doesn't really bead as much as compared to collinite's it actually sheets water more than it beads, but repellancy against water isn't its main forte although its sheeting is already sufficient to remove a majority of water after a wash, its number one feature is the protection it offers with the ease of a spray wax meaning it can provide a tough layer against water marks, tree saps and bird droppings, some sites even consider it as a sealant, anyways its second forte is the longevity of the shine compared to most OTC waxes that again comes with the convenience of the spray, i find that it actually lasts longer than TW PUG, Step 3 and Gold Class pastes when it comes to longevity of shine, so its more of a summer wax and a wax booster, for really round and tight water beading you really reach for the collinites
    Aug 2009
    #5506
    Quote Originally Posted by scharnhorst View Post
    ^^ apparently. hehe. hindi talaga nagbi-bead masyado (either that, or nastrip ko yung 476! hindi naman siguro!)
    and tama si ma'am madkatz - 2 sprays lang per panel (3 sa hood, 4 sa bubong), may coating na
    and unlike yung sa mother's FX na spraywax, walang buffing required kasi habang iniispread, makintab na agad
    ganda tingnan. hehe. tinapalan ko pa ng nanosliq para masarap rin haplusin :rofl:
    *PSI: sinubukan kong gamitin yung microtex na wax applicator para sa 476, ang hirap pala, naninigas kasi. mas madali gamitin yung yellow na foam na bilog for collinite na paste.
    pero pag liquid mas okay yung microtex na applicator
    for starters the foam pad is the easiest to use and apply thin layers, but with some practice and style the MF applicator can be easier especially with liquid waxes
    Aug 2009
    #5507
    Quote Originally Posted by azzkkr2600 View Post
    mga sirs and ma'am madkatz, ano ang mas okay na size ng ccs pads, 6.5 or 5.5? good deal na yun rotary ni sir jmpet kaso dapat tlaga magtraining magrotary. mahal kasi ng portercable at 110v pa.
    In most ways i agree with JM he's right, but my take would depend on the machine. if you're talking about the rotary when my suggestion is that you get the 5 inch backing plate like what JM get for me and my BF and then use the 5.5 inch pad for correction purposes, you see using the 8 inch pads are good if you're working the polish and spreading and working glazes and waxes since they don't require that much pressure, using a polishing doesn't require much pressure and no pressure in applying glazes and sealants, however when it comes to cutting pads you tend to need pressure and this is where i find the 5.5 inch does a better job since you can angle it to contour the curves better than the larger pads and you can concentrate the pressure on the defect area making your passes more effective in reducing defects, of course it requires more passes to do one hood but i find it more effective when working with smaller pads and that bonus is that you don't dry buff too quickly
    Aug 2009
    #5508
    Quote Originally Posted by jmpet626 View Post
    Actually we have tried the griots 5 DA polisher, and its only with their version two did they incorporate enough power to do the corrections better than PC, but the draw back that we noticed was that the Griots wiggle and vigrate more than the PC, we think its not that balanced as compared to the Griots, then again maybe its because we used a different counterweight for a different backing plate, see we used the counterweight for the 4 inch pads with a 5 inch backing plate.
    Aug 2009
    #5509
    Quote Originally Posted by kafph2000 View Post
    You will know if the product is sufficient if you can remove the swirls on one small area, so try doing a test spot, and if you can get the desired results then the product is enough, its just that some people hand polish and get excellent results from the start and poor results in the end caused by muscle fatigue and tiring, its normal for this to happen actually even for me thats why i usually recommend doing it a few panels per week, not do the whole car in one day, its no fun if you tire yourself too much at the end of the day, detailing should be fun hehe, but if on one small test area you still don't get the desired results then maybe its time for a second application or a more aggressive polish
    #5510
    Time to wash the Vios again tomorrow. Hopefully meron pang 476 hehe. It's been 2 weeks since I applied the 2nd coat of 476. And 1 week mahigit na no-washing. Hahaha. No time kasi.
    *madkatz
    mam paano po solusyon sa "mapping" sa isang part ng paint? Yung parang bilog na shape niya. Para bang nabalatan yung paint.
