Page 561 of 591 FirstFirst ... 461511551557558559560561562563564565571 ... LastLast
Results 5,601 to 5,610 of 5910
    Feb 2009
    #5601
    For me aksaya lang talaga ang jelly blade. Panget na pag konti nalang ang tubig. Parang arte nalang. Learn how to do water sheeting guys! After nyo gawin yun almost tuyo na yung car konti nalang ang tubig. Spot drying naman using your drying towel sa mga natira and curves then tapos na.
    Be practical guys hindi dahil mahal eh effective na. There are other ways to do it and not always "by the book" style.
    May 2009
    #5602
    sir.. nung nagpunta ako sa Autobisyo.. may nakita akong grit guard na kulay red. you may want to inquire kay Jerome.
    Quote Originally Posted by jmpet626 View Post
    So far wala pa nga ko nakikita seller gusto ko din bumili. Pwede ata siya sa mga 5 gallon buckets yung ginagamit na lalagyan ng paints. Yung mga bucket na normal parang hindi kakasya eh.
    Jul 2006
    #5603
    Quote Originally Posted by mau2485 View Post
    +1 kay Mau. Proper sheeting lang then Microtex Elite. Swabe na !!!
    Aug 2009
    #5604
    Quote Originally Posted by boklogs14 View Post
    so ok lang pala mag pa machine wax every month...akala ko po parang mga 4 months bago ako pwede mag pa buff..may nagsabi kasi sa akin na pag lagi daw ginagawa yun parang mawawala daw yung top coat.kasi hindi po ba after mag buff mainit init pa po yung paint..kaya ganon po pagkakainitindi ko regarding sa pag buff..thanks po.
    if it is always buffed to the point where it generates too much heat its already painful to touch then thats really bad for the paint and you shouldn't even do it at all, for the really skilled detailers they don't really get the paint hot, just a little warm and this is talking about compounding and polishing, if the place you're going to makes the paint really how when its just a machine wax procedure then there's something wrong with what they're doing if its a little warm then its ok. Machine wax doesn't really contain any abrasive particles so once its used properly it should not be able to reduce any significant level of clearcoat but if it gets too hot then again there's something wrong there.
    Aug 2009
    #5605
    Quote Originally Posted by Reepicheep View Post
    So what can I at least do every month to remove some swirls? My new monty is already getting some.
    Hehehe well if you're planning on removing them then you'll need a polish for that, and that means reducing clear coat, so why not just fill them? there's Microtex Nano Glos, NXT, and step 2 for that
    May 2008
    #5606
    Quote Originally Posted by madkatz View Post
    Well that's what I'm doing right now, spot step 2. Ganun na nga lang siguro. Btw, thanks for your advice, will opt instead for Microtex elite. Kay Edwin ko na rin kukunin.
    Mar 2005
    #5607
    Got it for 1.3k if I remember it correctly.
    Yes sir plush lang with aid of my blower. Will buy a jelly blade soon para mas madali.
    San nyo nabili sir mura na yan sa 1.3k sakin JCk din 1.5k bili ko. Meron siyang parang bag na itim na attatchment para saan kaya yun?
    Mar 2005
    #5608
    Quote Originally Posted by beeco View Post
    nag inquire ako 850 each...
    Aug 2009
    #5609
    Quote Originally Posted by Big_daddy View Post
    Hi all,
    Will Klasse AIO be able to replace a true polisher for nothing more than the most light swirl marks/bird dropping etches and water marks?
    I'm seriously considering using a polish to remove light scratches, but apprehensive about the results since I don't have access to a RO machine polisher and intend to just use hand polishing.
    TIA
    if they're really really light then yes it can help in removing some stains and visually eliminating scratches
    Aug 2009
    #5610
    Quote Originally Posted by weszt View Post
    *jmpet626
    sige try ko sila tawagan tomorrow kung nagbenta sila. kakatamad kasi to my transformer pa..ehe
    *madkatz.
    meaning yung AG SRP sealant na din yun? hindi ko na pwede lagyan M21 pag nag lagay ako ng AG SRP... balak ko kasi pag ka polish ko ng AG SRP , lagyan ko ng M21 tapos yung nxt gen tech wax 2.0 na paste. pero sympre caly muna..
    cge yung bosch na lang muna bibilhin ko pang wax at pang polish ko yun...
    eto ba ung sinasabi mong WP1300
    http://www.blackanddecker.com/produc...view=4#details
    ibang model n yan 11amps parang malakas na talaga yan...hehe
    pag nagamit naman ng rotary diba dapat light pressure tapos wag papatagalin sa isang place. yun rpm lang hindi ko alam kung gaano kabilis
    It sort of functions as a cleaner sealant pretty much like klasse AIO but of course AG SRP finishes a lot better, and yes you can apply M21 after, the name of AG SRP is very confusing in the sense that its not really a polish
