Results 271 to 280 of 1418
April 18th, 2007 04:03 PM #271
here's another sketch of mine. modern "jeepney" projector lamps if you will
April 18th, 2007 04:14 PM #273
ahihihi. if the military wants to win the war against terrorism, better do it in style, pinoy style that is.
April 18th, 2007 04:16 PM #274
in case Pinoys would like three wheelers, this might solve the problem. ofcoarse with a dash of pinoy owner type jeep modern lamps.
April 18th, 2007 05:07 PM #275
April 18th, 2007 07:01 PM #276
I start with pencil and paper, then I use CorelDRAW. But these drawings can be done in any 2D drawing software such as the one in MS Word or in OpenOffice (which is free). Another freeware is Inkscape. http://www.inkscape.org/
The advantage of using a 2D software is that guidelines (for perspective) can be drawn on a separate layer and items such as the wheels can be reused for other drawings by copy and pasting. Colors with gradients can be added to make it look realistic.
April 18th, 2007 08:26 PM #277
Interesting three-wheeler. Similar to a Grinnall ( http://www.grinnallcars.com/ ) but in a way better than that three wheeler because safeorigin's design has a roof. They both have the correct layout (two wheels in front and one at the back) for high speed and safety. The other layout (two wheels at the back, one wheel at the front) is for low speed and heavy loading.
How do you add an air-conditioning system to the motorcycle engine? One possible solution: use a hybrid vehicle's air-con because the compressor is run by an electric motor (not by the usual belt to the engine). Pero wala pang hybrids dito sa Pinas.
The three-wheeler will need an electric reversing mechanism. Wala kasing reverse gear ang motorcycle.
My comments about the design: IMHO the front end is a mess and the fenders are too big.
Safeorigin, will you allow me to clean up and redraw your design? I humbly request your permission.
Tsikot Member Rank 4
- Jan 2003
- 1,403
April 18th, 2007 08:39 PM #278Sure as long as you can turn the gun around and shoot stupid drivers with blinding lights. j/k.
OT RANT: Just earlier this evening, I was on Mabini towards Wilson when a guy on a motorcycle (ZJ 7246) behind me suddenly turned on his light. It was blindingly bright that I was momentarily blinded. I had to brake abruptly as I couldn't see in front of me. The guy turned off his light and I moved forward. He turned it back on again, blinding me again. Again I braked abruptly. He turned it off and moved to the right lane and turnd it on. The car in front slowed down immediately. Why he has to installed a blinding bright light and risk the ire (and safety) of other motorists is beyond me. The fact that both he and his female passenger were without safety helmets somehow did not surprise me.
- Jan 2003
- 1,403
- Jan 2003
- 1,403
April 18th, 2007 11:22 PM #280Redundant post deleted. Something weird is happening. The system seems to be regenerating my last post on its own.
