Page 28 of 29 FirstFirst ... 18242526272829 LastLast
Results 271 to 280 of 287
    #271
    I might be wrong about the origin of ADR. But im sure evercool is locally made.
    nag sms ako dun sa number sa evercool fb page
    wala pa reply hehehe
    bakit kaya yun 3 store na natanungan ko sa banawe wala sila nun
    Sep 2018
    #272
    Quote Originally Posted by batang_angas View Post
    Hello po again. I'm having temperature issues po with my 03 Honda City Type Z. The temperature is getting high so I stopped at the nearest gas station to get water to cool down. There were some bystanders who helped me out to figure out what's wrong with the car. They are saying that the radiator was clogged.
    Here's what I know so far:
    -the fans are working fine
    -I'm not losing coolant and water from the radiator
    Sent from my LDN-LX2 using Tapatalk
    Other possible reasons why your car is overheating would be electrical problem or damaged thermostat or water pump. However, I suggest that you should visit your trusted auto shop to have your car checked to prevent any further damage to your car. Hope this helps!
    #273
    installed new rad ..
    lesson learned, if you know youve been using coolant since day 1. wag ipa overhaul ... LOL
    lesson learnt is true bro. walang corrosion!
    #275
    Two rows? And don’t forget to “burp” the cooling system to release some air pockets that may have been trapped.
    #276
    Made of Aluminum o brass sya bro?
    #277
    alum parin bro and 2 rows nga sya.
    burped narin sya bros
    nanghinayang lang ako dun sa orig na rad since wala naman problema nung una, nagkaroon lang after ng overhaul
    #278
    keep it as spare. you might need it in 10 years. heh heh.
    or sell it. here.
    #279
    or sell it. here.
    planning to fix it talaga bro, then keep as spare or pamigay sa vios user na mangailangan or pwede rin benta; whichever comes first LOL
    Dec 2017
    #280
    This is unfortunate, when you fixed something that is not damaged and now is broken...
    This is good information for those who are new to cars, leave the radiator as it is if you are using coolant. Follow manufacturer's recommendation for its interval when to replace the fluid.
Radiator / Overheating Problem
