Page 24 of 29 FirstFirst ... 14202122232425262728 ... LastLast
Results 231 to 240 of 287
    #231
    ^bro try mo daw compression test. not really sure how it would help, pero nabasa ko lang hehehe
    antay natin mga tips ng iba
    #232
    Quote Originally Posted by Bunwa View Post
    I've had overheating problems last month. Now the initial observation was, its a cyclinder head issue since nauubos yung fluid sa radiator at reserve at bumubulwak nung tinest yung flow ng coolant/water. PinaLavramon ko yung engine tapos nung tinignan yung radiator sinuggest na palitan ko yung radiator. So upgraded na sa 2-row aluminum radiator at di na nagoverheat pero nung pinainit to test kung nag circulate bumulwak pa din. My question is, should I be concerned that its a cyclinder head issue since di nag overheat at stable na yung coolant supply, na di nag drain or apaw at wala naman yung one of the signs na milky white substance sa oil cap?
    1. are you overheating, as evidenced by your temperature gauge?
    2. are you losing coolant?
    3. are you both overheating and losing coolant?
    them are different things.
    May 2011
    #233
    It can have perfect compression test result even if the coolant is leaking into the combustion chamber s.
    The preferred test for this concern and is more conclusive is a cooling system pressure test.
    Feb 2005
    #234
    if you're not overheating or not even getting high temp on your gauge that shouldn't be an immediate concern. Now, question is gaano kadami yung bumubulwak sa radiator? afaik, kung hindi naman masyadong madami or malakas ang pag bulwak normal naman may bubulwak dyan pero dapat konti lang lalo na kung sarado pa thermostat at the time of testing, paki correct na lang mga master...
    #235
    Bumubulwak on cold startup:
    1. Thermostat valve was removed by siraniko
    2. Thermostat valve is stuck open
    Oct 2015
    #236
    Before the old radiator was replaced, check on 3 but not anymore. I'm just concerned when I was told it might be a cylinder head issue since bumulwak yung tubig but that only happens when the temp is extreme not when it is cold
    nung nirev kasi parang malakas yung bulwak but as the moment the temp is stable and the rad and reseerve does not run out of coolant. No milky white substance also on the oil cap per those guides I'm seeing online for a busted cylinder head/gasket
    #237
    Quote Originally Posted by mina_nuka View Post
    ito ba yun mga bicycle pump type na na DIY online?
    May 2011
    #238
    Google Image Result for https://images-na.ssl-images-amazon.com/images/I/81FUDTtRcL._SX425_.jpg
    Jul 2018
    #239
    Hello po again. I'm having temperature issues po with my 03 Honda City Type Z. The temperature is getting high so I stopped at the nearest gas station to get water to cool down. There were some bystanders who helped me out to figure out what's wrong with the car. They are saying that the radiator was clogged.
    Here's what I know so far:
    -the fans are working fine
    -I'm not losing coolant and water from the radiator
    Sent from my LDN-LX2 using Tapatalk
    May 2011
    #240
    Quote Originally Posted by batang_angas View Post
    If the overheating just happened, maybe the coolant level was low or maybe the thermostat was stuck closed. At that age I would replace the thermostat whether it still opens normally or not.
Radiator / Overheating Problem
