Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
    Mar 2004
    #21
    Every 1-2 years: Have evaporated cleaned, refrigerant (Freon) checked and / or refilled, compressor oil checked and / or refilled, compressor o-rings replaced ...
    #22
    Quote Originally Posted by nightfox View Post
    Humina na yung lamig ng AC ulit - hindi umaabot sa 2nd row ng car.
    May pinapalinis ba dapat regularly or may kailangan irefill?
    Thanks
    hindi na lumalamig, o mahina ang buga?
    freon, or blocking dirt?
    the aircon guys can check the freon levels, to see if you need a refill.
    but if you need a refill, then you must have a leak somewhere.
    Feb 2019
    #23
    2) I tried turning the fan to level 2, hindi nagrorotate both fans. I tried switching on the A/C knob, and then yung radiator fan lang ang umandar. Is this normal?
    Audacity Find My iPhone Origin
    Feb 2013
    #24
    Thanks. So apparently, nagpaAC cleaning na lang ako (air filter replacing/cleaning) - costed me about 2-3k. Lumamig naman siya, umaabot sa 2nd row pero mukhang malabo na umabot sa 3rd row.
    It was good - was able to test it during the extreme summer hot weather. After 2-3 weeks though, I noticed something:
    1) Lumalamig pa rin naman pero humina yung fan (or pagblow ng air)
    2) Minsan sobrang hina ng pagblow ng air sa loob pero if you touch the AC vents, malamig siya. Yung feeling is nagbblow siya ng cold air pero yung sound parang sa loob ng vent siya bumubuga (kumbaga hindi makapasok sa loob ng car). Malamig naman pero yun nga, hindi aabot sa driver's seat.
    3) Paglabas ko, there are water leaks pero parang hindi usual kasi nakikita ko rin sa ibang areas (see 2 videos). Usually isang area lang naman lumalabas yung AC water diba? I noticed na merong ibang areas sa ilalim ng car na basa rin - unless normal talaga dahil mainit and nakamax temp yung setting ng AC?
    4) Mukhang wala naman leak sa coolant so I should be safe but you can enlighten me if I missed something.
    5) Sometimes, pinapatay ko yung makina na lang muna. Pag-on ko, malakas ulit yung AC then #2-#3 happen again after sometime (siguro mga 30-40 mins after)
    Video Links:
    Minsan napapaisip ako na magpainstall na lang nung aircon na kinakabit sa 2nd row (yung mga gamit minsan sa public FX). Safe and okay ba yun?
    Thanks in advance!
    #25
    Video Links:
    Thanks in advance!
    Nag ice yun A/C mo
    Feb 2013
    #26
    Nag ice yun A/C mo
    what/how do you think this can be fixed? mahal kaya or simple lang?
    is it the same as this one? Car AC Lines Freezing Up? Here's What You Can Do About It
    #27
    Either low in freon or super dumi na talaga.
AC problem on CRV 2003
