Results 21 to 30 of 34
May 3rd, 2007 09:57 AM #21
- Nov 2006
- 103
June 24th, 2007 02:28 AM #22ano po kaya pdeng naging prob sa 97 accord exi a/t ko...kaka change oil ko lang ska spark plugs (ngk platinum)...feeling ko mas lalo lumakas sa gas!!! help pls
June 24th, 2007 05:44 AM #23
Nice info and reference. Thanks for sharing.
:coffee: [SIZE="1"]3054[/SIZE]
July 12th, 2007 07:22 PM #24
mga sir, paano kung sa thread ng plugs may oil. ano kaya cause nito? sabi daw sa plug oil seal daw sa may rocker arm. magkano po ba yung oil seals each? tia
July 20th, 2007 01:37 PM #25
July 20th, 2007 01:42 PM #26
minsan psychological lang yan bro.. bagong change oil and spark plugs.. lumakas hatak ng car mo for sure.. nanibago ka siguro sa tapak ng gas ksi lumakas nga sya kya bka d mo nappansin mejo hinahataw mo na rin. hehehetry mo rin i-re tune up ang distributor sa tamang timing or minsan i-reset mo ang ECU..
July 21st, 2007 09:10 PM #27
- Aug 2006
- 110
October 6th, 2007 07:04 PM #28I just replaced the spark plugs of my 2002 Nissan Cefiro after more than 5 years and 52,000 Kms. The OEM spark plugs installed are NGK PFR5G-11 (Platinum). The replacement plugs I bought were NGK PFR6G-11 setting me back PHP 450.00 a piece or PHP 2,700 total! The only reason I replaced them was because I felt the engine misfire once or twice during idling this past week. Sinabay ko na ang fuel filter. The mechanic told me that the fuel filter was dirty (5 years old na kasi!). Maybe it was the dirty fuel filter which caused the engine to misfire. Had I replaced the fuel filter first, maybe I would still be using the original spark plugs. Platinum and Iridium spark plugs last a lot longer than regular plugs, but are more expensive. I do not change plugs every time I get an oil change and I don't think you have to especially with cars that are fuel injected and have full electronic ignition. My other ride is a Grandis and it uses Iridium spark plugs. Hopefully the Iridium plugs last longer than the Platinum ones. Platinum/Iridium plugs are supposed to last from 80,000 to 100,000 Kms. You can visit the site, www.ngk.com for more info.
October 13th, 2007 05:17 PM #29
October 13th, 2007 05:25 PM #30
Tesla Philippines
