Results 11 to 20 of 29
    O/D ON lang lagi, whether city driving or highway driving. saka mo lang i-Off ang O/D pag nasa bundok ka, for example pag paakyat o pababa ng baguio.
    Huwag makalikot sa 'kambyo' ng A/T. Ano iyan,- M/T?....
    14.0K:bike3:
    Oct 2008
    does this also apply sa mga lancer na 2002 model? (glx)
    Sep 2011
    Mga sir ask ko lng kc ung akin pag naka on tapos prang bigla sya nag rrealease pag aapak na ako ng gas parang release lng.. manual type kc ako mga sir.. so since bnili to ng sis ko nka off daw sya lagi.. pag naka on nmn sya prang minsan relaese lng talga
    Quote Originally Posted by azlanie View Post
    [SIZE="4"]REMINDER: do not post messages in SMS/TXT shortcut format.
    Read the rules.
    Ignorance of the rules is not an excuse.
    Repeat offenses will lead to banning.
    [/SIZE]
    Oct 2011
    No "O/D OFF" light means the O/D is "ON".
    As I have said, you would normally want the overdrive active to give you better fuel mileage.
    ask ko lang po sir, so kapag nakalagay sa dashboard na O/D off meaning its on right? naguluhan kasi ako sa post ni sir QWERTY e.
    just leave OD on.. dapat walang ilaw sa dashboard..
    eh sabi ni sir ghosthunter pag nakailaw sa dashboard meaning its "ON" ? eh bakit mo sinabi dapat walang ilaw sa dashboard? hehe medyo nalabuan lang ako sir.
    hindi ganyan ang gamit.. ilagay mo lang sa ON parati.. wag mo nang gagalawin.
    Quote Originally Posted by beebski View Post
    Ang design ng mga dashboard ng mga sasakyan ay minimalist.
    Ibig sabihin,- ang mga display nila ay 'idiot lamps'.... Kapag walang ilaw,- normal na driving experience at walang problema. (Of course, headlights during night driving is a must)
    So, kung naka-on ang ilaw ng "O/D Off",- ibig sabihin may setting na "outside ng normal driving". (Naka off and OD)
    Push the pertinent button. Dapat walang naka-ilaw na idiot lamp sa dashboard.
    14.2K:juggle:
    Jan 2008
    sa mazda 323 ko dati HOLD ang naka indicate instead of O/D... so pag naka ilaw yung HOLD means O/D off vice versa...
    O/D off means HOLD the transmission.. sa D mode up to 3 gears ka lang...
    Yup, iyong Gen3 Starex namin dati.... May O/D on/off switch sa "stick"(ng A/T)....
    Tapos may Hold switch pa sa may lower left side ng dashboard (sa may ilalim/tagliran ng steering wheel shaft)...
    14.2K:juggle:
    basta on mo lang tinganan mo na lang kung hinde ka tumutulin eh di naka off yun O/D mo... pag malakas ka sa gas naka off O/D...common sense na lang. kung rekta ka na tapos ang taas pa rin ng rpm mo naka off o/d mo...etc etc.
Q. OverDrive ON / OverDrive Off
