Results 21 to 30 of 45
- Apr 2012
- 8
April 10th, 2012 07:35 PM #21
- Apr 2012
- 8
April 10th, 2012 07:40 PM #22
April 10th, 2012 09:45 PM #23
ako naman, once in a while i love to workout the monty's tranny on an uphill climb in makati's mall parking ramps
i would purposely drive real slow going up and at times, even stop midway (pag walang kasunod) and then climb up again
- Jun 2007
- 6
June 10th, 2018 09:52 AM #24
Hi, I'm now having the same problem on the tranny of my 2012 Montero Sport GTV (150,000 kms). After driving for more than 50 kms or more and on mainly uphill, the "D" blink (engine check light on) and the transmission is stuck at 3rd gear. Even if I stop and Park, then proceed to drive it's in 3rd gear, which means from stop position.
I was advised by a mechanic to overhaul the transmission and after doing so the same problem persists. Now what I'm doing if the "D" blink and engine check "On", I stop the engine and restart. It will work properly for a while with engine check still "On", but after few kilometers the "D" will blink again and has to start from engine off.
After several days the engine check will automatically turn-off and light "On" again when the "D" starts to blink.
Any thought or experienced that can help on my dilemma? Computer checks had been done and even the input shaft speed sensor had replace.
- Jun 2007
- 6
June 10th, 2018 09:57 AM #25Hi, I'm now having the same problem on the tranny of my 2012 Montero Sport GTV (150,000 kms). After driving for more than 50 kms or more and on mainly uphill, the "D" blink (engine check light on) and the transmission is stuck at 3rd gear. Even if I stop and Park, then proceed to drive it's in 3rd gear, which means from stop position.
Any thought or experienced that can help on my dilemma? Computer checks had been done and even the input shaft speed sensor had been replaced.
June 10th, 2018 11:43 AM #26
^if you have changed ATF at 40thou km then its the mechanical issue already
If not try to change the ATF first
Sent from my GT-P3110 using Tsikot Forums mobile app
June 10th, 2018 01:22 PM #27
- Jun 2018
- 1
- Jun 2008
- 360
June 14th, 2018 09:36 PM #29Regarding sa Pagsteady ng Tranny sa Gear going Uphill:
Sa tingin ko normal ito sa montero lalo na kung mabigat ang paa mo at matulin ka paakyat tapos palagi o madalas ang shifting ng tranny due sa pabago-bagong speed.. Naexperience ko na ito maka-ilang beses sa kennon road.. At first akala ko din talaga may problema pero nung nakasanayan na parang nakapag-adjust na ako sa pagmamaneho..
Sa GLS SE hindi ko nga lang maalala ko naexperience ko ito pero Sa GTV sure ako..
June 14th, 2018 10:00 PM #30
yung pag-steady ng gear sa uphill/downhill is about the adaptive transmission control feature. kapag na sense ng ecu na madalas preno at pag-menor sa downhill/uphill, mag-activate yung adaptive control at mag steady sa 2nd gear. reset lang sa neutral then back to sports mode. o kaya naman tumabi, switch off then on the engine.
the one mentioned earlier at nag blink yung "D" is a typical error caused by faulty inhibitor switch. common sa gen.2 montero. it needs to be clean or kung sira na need na i replace.
Tesla Philippines
