Results 11 to 20 of 29
BANNED BANNED BANNED
- Sep 2015
- 13,917
October 9th, 2015 06:40 PM #11I already told my brother vacationing out of the country.
Galing din ako sa apat na talyer. Buti na lang makulit asking opinion. First 3 talyer said change clutch disk, pressure plate, release bearing. Pero i still have doubts because i tried the clutch test and ok pa naman.
The culprit was cv joint nahuhugot. 99% sure na ako ito. One last talyer pa.
Ang hirap talaga pag kotse hindi pwede maniwala agad. Aayusin pero hindi pala yun sira.
- Sep 2015
- 13,917
October 9th, 2015 06:40 PM #12I already told my brother vacationing out of the country.
- 53,883
October 10th, 2015 12:41 AM #13errr... what car are we talking about, po?
CV joint..? why? the 3 talyers said transmission...
- 53,883
October 10th, 2015 12:41 AM #14errr... what car are we talking about, po?
- Jun 2005
- 3,774
October 10th, 2015 01:18 AM #16nahuhugot pala ang cvjoint?
mas duda pa ako sa diagnosis na cvjoint eh. mas feasible ang clutch problem.
cv joint problem should not give you erratic symptoms dahil purely mechanical ito
- Sep 2015
- 13,917
October 10th, 2015 01:51 AM #17Honda Civic VTI.
The 3 talyer said sliding daw because of the whistling sound daw sa clutch.
They tried the clutch test pero dapat if you release the clutch magmaintain na naka on engine if sliding. Pero nagoff eh.
My brother told me na the whistling sound since 2010 pa.
Oo meron tok tok tok sound. Nung hindi ako magaccelerate meron tok tok tapos pag nakaaccelerate nawawala tok tok sound.
Doon sa fourth talyer kasi sanay sa honda cars kaya pinuntahan ko. Sinasabi ko pa lang symptoms eh sabi ng mechanic "driveshaft daw" kaya nashock din ako kasi not the usual sliding na clutch. He repeated if meron tumutunog sabi ko meron pag hindi makaaccelerate pero nawawala if nakaaccelerate
Nahuhugot daw yung bearing ata sa driveshaft kaya parang "sliding"
Meron ako nakausap 5th talyer and confirmed the 4th talyer diagnosis pero kailangan nya makita dalhin ko later.
By the way so far hindi pa bumabalik yung hindi mag-accelerate. Dahan dahan pag gamit ko steering.
- Sep 2015
- 13,917
October 10th, 2015 02:00 AM #18Ito kausap ko brother. Year 2005 napalitan daw replacement sa banawe cv joint plus cv boot. Not the buong assembly drive shafts.
The 4th talyer explained to me na dahil replacement type na daw driveshaft kaya ganyan.
- Oct 2015
- 13
October 10th, 2015 02:46 PM #19ako may problem din sa manual tranmission ko ngayon post ko na lang sa thread
- Sep 2015
- 13,917
October 11th, 2015 12:44 AM #20Nag research ulit ako online and from 99% eh 99.8% na ako ito problem ko.
CV joints - Car Talk
A bit of a flare for the dramatic there. I'll tell you what, mjkelley - if you have a sudden CV joint failure that sends your car end over end on the highway, and if you live through it then buy a lottery ticket as soon as you can b/c you're apparently on the thin side of the odds that day.
I'm not saying squirrely things can't happen b/c they can, especially at high speed. But basically if the joint completely fails it cuts transfer of power from the engine/transmission to the wheels. So the most common thing that happens is that the car just won't go. If you are driving it you will find that you can't accelerate & will come to a stop. If you're stopped you'll remain so. The squirrely things can happen b/c there are multiple axles w/ 2 joints each.
CVJ's click bad and quit altogether when they are past bad. You get 0 power to the driving wheel. The inner joint spins in the outter joint then. You just hear rattliing and get no go.
Read more: Can defective CV joints cause drag and sluggishness? (idle, brakes, tires) - Automotive -Sports cars, sedans, coupes, SUVs, trucks, motorcycles, tickets, dealers, repairs, gasoline, drivers... - City-Data Forum
Tesla Philippines
