Results 21 to 30 of 39
- Jan 2007
- 2,452
July 2nd, 2021 11:01 AM #21Even known "Master Mechanics" who specialize in a particular brand most of them only do drain and refill. Check out M539 restoration's channel. The guy is a BMW wizard. He picked up a very cheap (and known for problems) E60 M5 which he fixed up, and even with internal damage to the engine he's only doing frequent drain and refill oil changes until metal shavings stop showing up in the drained oil.
- Feb 2013
- 919
July 13th, 2021 03:23 PM #22Ended up buying 7 x 1 quart of Amsoil CVT fluid as I really can't find any good references in the Internet about people using Mitasu aside from the Philippine/Asian market. The total price from Oil Shack (Lazada) was very very good last 7.7 sale.
July 13th, 2021 03:32 PM #23
I used Mitasu as suggested by FusionR a few years back. I guess the rest of the folks in SFX community also have the same experience as me.
Somehow, dumadami na rin gumagamit ng Amsoil CVTF. I might use that on my next CVTF change.
- Feb 2013
- 919
July 13th, 2021 03:54 PM #24Mukhang sikat naman nga yung Mitasu dito. Both 2211 Works and FusionR told me that they never had problems with the brand. I just know that they just repack their CVTF and I'm not sure which OEM fluid they use.
On the same note, I also didn't find any negative reviews against Amsoil CVTF.
- Nov 2010
- 15
August 30th, 2021 07:19 PM #25Hi. I just got my 2018 FXT and this is my first Subaru. I am excited to be part of this discussion. I was of the impression that Subaru does not recommend replacing the CVTF because they say it is maintenance free. So does the casa now change the CVTF if you ask it to be changed?
August 30th, 2021 07:34 PM #26
Nope, it is not maintenance-free. Subaru requires replacing CVTF every 40k km. They can do it at the casa (dealership) but they will have to replace everything. That’s 13L via dialysis method. It would cost you around 18k.
If you go to the aftermarket shops that specialize in Subaru, they can do drain-and-refill method which needs around 6L.
By the way, the XT/WRX/Levorg/Outback/Legacy uses a different type of CVTF compared to the non-turbo Subaru (Forester/XV/Impreza).
- Nov 2010
- 15
August 31st, 2021 04:18 PM #27Thank you, Sir. By the way, my odo is still at 30k, but the previous owner already had it serviced until the 50k pms. CVTF was not replaced at the 40k pms. Is it too early for me to have the CVTF replaced?
Sent from my Pixel 4 XL using Tapatalk
August 31st, 2021 07:25 PM #28
Subaru requires actual mileage so have the CVTF replaced at 40k km. You can bring it to FusionR and also include changing the gear oil (front and rear). I guess that would cost you around 10k for the CVTF and gear oil change.
Once a year na lang ako change oil with my XT. Di man ako umaabot ng 10k km in a year. Just make sure to use 5w30 FS oil (API SN, ILSAC GF5).The XT requires around 5.5L of FS oil. I use Amsoil FS oils, by the way.
- Nov 2010
- 15
August 31st, 2021 09:13 PM #29Thank you for this info, Sir.
By the way, is there any disadvantage if I have the CVTF changed in full versus just the drain and refill, apart from the higher cost?
August 31st, 2021 09:30 PM #30
Tesla Philippines
