Results 1 to 10 of 11
- Aug 2012
- 12
October 14th, 2012 12:29 AM #1Good day everyone! I own a Nissan Exalta STA 2000. Just wanna know what are your shifting points? Yung exalta ko kasi nag early shift. When I depress the accelerator pedal and release it while running on a 30km/hr speed, mararamdaman ko na nag shift siya sa higher gear. So pag dine press ko unit yung accelerator pedal, mahihirapan siya to get the momentum cause walang bwelo. What could be wrong? If tuloy-tuloy naman ang depress sa accelerator pedal from a stop, ayos ang shifting points.
October 15th, 2012 02:11 PM #2
shifting points in an AT depend on the speed and the rev.
in your case, mukhang ok naman.
October 15th, 2012 02:26 PM #3
mukhang tama naman ang pagshift ng sasakyan mo.
normally sa sentra shifting points for stepping lightly on the accelerator are:
1st to 2nd gear *20kmph and 2K rpm
2nd to 3rd gear * 40kmph and 2K rpm
3rd to 4th gear * 60kmph and 2K rpm
pwede pang mapaaga kapag na-depress mo ng mas maaga yung accelerator just like sa nangyayari sayo * 30kmph shift to a higher gear na. if you say that walang bwelo you simply step on the pedal harder para mag adjust siya, the transmission will down shift para needed na power mo.
- Jan 2008
- 4,726
October 15th, 2012 03:27 PM #4teknik yan pag release ng pedal sa A/T to upshift early... if you need to down shift, just press the pedal further until mag downshift sya.. ayun may bwelo ka na...
October 15th, 2012 03:34 PM #5
malaki ba ang diperensya sa FC mo if you are a "heavily footed" driver as compared to light lang pag apak mo sa gas in A/T vehicles?
October 15th, 2012 03:36 PM #6
Very. On a light foot the AT will shift up early (before 2k rpm minsan). A heavier foot will make it shift slightly later. Floor it and it will go all the way to redline.
- Aug 2012
- 12
October 16th, 2012 01:44 PM #7
Tesla Philippines
