Results 61 to 70 of 370
May 28th, 2013 04:17 PM #61
Had mine done at Fronte in Banawe for our Starex, dialysis process also, it now pulls good as new. Van was hesitant to pull after upshifting before.
May 28th, 2013 04:28 PM #62
June 15th, 2013 09:39 AM #63
nag-inquire ako sa mitsubishi casa... gumagawa daw sila ng dialysis process pero 6 liters lang daw ang kailangan na ATF. total cost would be P5400. is that really a complete dialysis? sabi naman nila yes daw kasi they will also drain the torque converter.
nagtataka lang ako kung bakit 6 liters lang eh parang nasa 10 liters ang nakalagay sa manual...
June 15th, 2013 10:00 AM #64
i wonder kung gumagawa nito sa customer's cradle or servitek las pinas (just before alabang)
anyway, medyo maselan ang mga honda sa atf so kailangan ba lahat ng atf ipasok habang dialysis iyong oem atf? ours kasi is a civic fd 2.0 s-l so i suppose medyo madami-dami ang atf na kailangan ko nito
- Jul 2011
- 1,711
June 15th, 2013 10:23 AM #65
June 15th, 2013 01:30 PM #66
June 15th, 2013 02:37 PM #67
That's expensive. Did they show you their dialysis machine?
The number of litres used for the process depend also on the extent of the dirtiness of your existing ATF. Years ago, i used 20 litres on a used Corona we bought (the total bill was P 5,000+ at Autotechnika when it was still open).
- Jul 2008
- 935
June 15th, 2013 03:28 PM #68I just change the ATF of my Hi-ace everytime I change the engine oil. It always have the shiny and clear color. No problems with the AT so far. I'm planning to dismantle the pan underneath but it seems to be a tedious job. So I guess regular short time interval of ATF change is better and more practical than this dialysis method.
June 15th, 2013 03:41 PM #69
- Nov 2009
- 3,503
June 15th, 2013 05:05 PM #70For hi mileage cars with 1st time to replace ATF, you can have this same or better results than dialysis..
1. Drain AT fluid
2. Remove the pan, replace AT strainer and gasket.
3. Re-fill
4. Use the car for 1k. (This will allow fluid to dissolve some more sludge)
5. Drain and re-fill again.
Tesla Philippines
