Results 11 to 20 of 29
February 21st, 2019 02:23 PM #11
- Jul 2018
- 22
February 21st, 2019 03:21 PM #12
February 21st, 2019 03:44 PM #13
Pedeng sa engine bay ka na mismo sumilip. Patulong ka nalang sa iba galawin yung shift stick, makikita mo dapat gumalaw rin yung linkages nya papuntang tranny.
Kung 4afe yang engine mo makikita mo yun kapag tumingin ka straight down, i think sa likod banda ng tranny, sorry limot ko na. I guess kung 2e man yan di sila magkakalayo ng location.
- Jul 2018
- 22
February 21st, 2019 04:05 PM #14
- Jul 2018
- 22
February 21st, 2019 04:18 PM #16
February 21st, 2019 04:20 PM #17
- Jul 2018
- 22
February 21st, 2019 04:42 PM #18
- Jul 2018
- 22
February 22nd, 2019 10:00 AM #19well, update: it was all due to air trapped inside the clutch pedal system. a good friend came to my rescue and took only one check of the fork, told me it should have some play.
what happened was that the slave cylinder pin was pushing the fork (like having the clutch pedal pressed midway), so that's why my clutch was perpetually disengaged and explains why i can shift gears without even touching the clutch pedal. a simple bleeding of some clutch fluid eased the slave cylinder and gave us some space between the fork and the push pin.
while at it, i also looked at how the gear shift works externally.
apparently, the mechanical stuff under the hood can survive pyroclastic flow, and only operator error (inc. an idiot like me) would cause it not to work
thanks to the good folks here at Tsikot for the suggestions! and cheers din sa lahat ng kaibigan natin sa buhay na parating maaasahan
February 22nd, 2019 10:23 AM #20
Hahaha! Ayos! Mas simple pa pala!
Tesla Philippines
