Results 11 to 16 of 16
September 21st, 2015 05:57 PM #11
anong sasakyan ba sir ang tinutukoy mo na modify mo?
yung condenser mo is more suited sa harap, kasi mas safe yan dyan sa area na yan, at makaka kuha ng airflow as the vehicle moves.
i do not believe that you are going to hurt your ATF fluid if you are not towing.
i have used my vehicle for towing, almost 1 ton of trailer cargo for 60kms of bad roads and an additional 10 kms of very bad road. after 2 years i just changed the ATF, the fluid is not yet even brown when i had it changed.
just use a very good quality ATF fluid and you will be safe... i dont think you are towing or putting 1 ton of weight on your vehicle to necessitate an additional cooler.
September 22nd, 2015 03:57 PM #12
i would say option 1. retain the oem trans cooler sa engine radiator. nagsisilbing "thermostat" ng atf yung oem cooler sa radiator. kung ibypass mo ito e baka magovercool ang atf kung highway speeds na. i read somewhere sa foreign forum na parehas ang effect ng overcooling at overheating sa atf (auto transmission).
typical pressures ng oil pump ng auto transmission ay nasa 200 psi. gamit ko noon ay hydraulic hoses at stainless hose clamps. di naman tumagas. ewan ko na lang ngayon sa pinagbentahan ko. mas maganda kung pagawan mo ng hydraulic fittings para kung sakali mag change oil ka e unscrew mo na lang yung hose. hindi na sa drain plug na napakalambot ang threads.
sa dati kong sasakyan, bumili ako ng surplus na oil cooler galing sa 4d56 (L200/pajero/delica) for about 1.5k lang. kung makakuha ka ng trans cooler galing sa delica mismo mas maganda. just be sure na malinis mo ang loob nito ng mahusay kundi masisira ang trans mo sa kaunting debris lamang.
no need na sa tingin ko ang cooling fan na dedicated sa trans cooler.
- Jun 2012
- 269
- Jun 2012
- 269
- Jul 2007
- 6
January 19th, 2016 05:50 PM #15mga sir, would like to ask if anybody has installed a tranny oil cooler for honda jazz CVT. Planning to install one kasi pag stuck in traffic na, hirap na humatak, pero pag lumamig na ng konti, ok na hatak. Hindi talaga maka adopt/design ang cvt sa ubertraffic dito sa pinas.
Can you recommend a shop that can install one, QC area.
Thanks
January 19th, 2016 06:20 PM #16
No need for a bypass, it's a direct air to air cooler naman eh. The tranny fluid will be passing thrpugh the core and the heat will be absorbed by the relative wind as it pass through the fins.
Tesla Philippines
