Results 831 to 840 of 1444
- May 2011
- 4
September 11th, 2015 12:44 AM #831Try mo canvass sa recto close to abad santos marami store sell replacement headlight mas makamura ka pwede na DIY Lang yan Madali Lang palitan yan.
- Sep 2015
- 8
September 11th, 2015 01:48 PM #832
- Jul 2011
- 71
September 15th, 2015 10:11 AM #833guys, ano kaya ang tamang size at model ng motolite gold battery para sa revo diesel 02 mdl?
recently kasi ayaw na mag start. i bought this 2nd hand so im not sure kung tamang model or gsm yun nakakabit ngayon..
- Apr 2008
- 6,235
September 17th, 2015 03:33 AM #8342SM pwede na. Motolite Gold din gamit ko. March, 2014 binili. So far so good.
- Nov 2008
- 641
September 17th, 2015 03:43 PM #835
2SM ok na as what Sir GTi mentioned. Pero make sure yung battery lang ang problema. Kasi kung talagang ok ang makina, starter at electrical system, kahit 1SM kaya yan. Pero syempre it is best to use the specified para tumagal. Better check your starter, check for loose and corroded connections, etc. Thanks
2SM ok na as what Sir GTi mentioned. Pero make sure yung battery lang ang problema. Kasi kung talagang ok ang makina, starter, pre-heat at electrical system, kahit 1SM kaya yan. Pero syempre it is best to use the specified specs para tumagal. May redondo ba? Malakas o mabilis ba ikot ng makina habang rumeredondo? Better check your starter, heater system, check for loose and corroded connections, etc. ThanksLast edited by jvnj; September 17th, 2015 at 03:49 PM. Reason: Additional recos
September 21st, 2015 05:16 AM #836
Mga gurus, may nakapag regear na ng ating ride? kamusta naman? gumanda hatak and acceleration? kamusta sa akyatan? nag stall ba?
- Apr 2008
- 6,235
September 21st, 2015 05:42 PM #837Have never fiddled with the tranny aside from the regular fluid changes. But then, I find the Revo's gearing to be very well matched to it's engine performance. It seems to be an excellent compromise between the Adventure (geared for high speed) and the Crosswind (geared for inclines).
September 27th, 2015 01:51 AM #838
AFAIK, magkaiba gearing/final gear ratio ng diesel and gasoline Revos, gusto ko malaman ano ba stock ng sa diesel(2L) kasi yung mga karamihan na nagpapalit is naka-gasoline engine, ipinapalit nila galing sa Toyota Crown.
- 53,883
September 27th, 2015 09:08 AM #839
September 27th, 2015 09:15 PM #840
Tesla Philippines
