Results 401 to 410 of 1444
- Apr 2008
- 6,235
August 16th, 2012 05:29 PM #401^Medyo may kamahalan ito dahil papalitan mo ang engine pati narin transmission. You'd have to be hunting for a good transplant engine and transmission, and this is a hit and miss matter. And then you have to be sure with the quality of the conversion or you might have more headaches in the future. Tell you what, you can instead trade your gas Revo for a diesel Revo. That's the safest way.
There's not much risk in getting a flooded diesel Revo too. Due to the old school nature there are very few electronic parts inside. The most you would probably be changing would be the starter motor or perhaps the battery, and then a thorough oil change.Last edited by GTi; August 16th, 2012 at 05:32 PM.
- Sep 2011
- 90
August 16th, 2012 09:37 PM #402^
Thanks GTi. Yon din sir ang iniisip ko baka if magchange aq ng engine. Savi kasi ng mechanic na gumagawa may maingay daw sa loob ng engine t ang transmission is kailangang ibaba na kce mahirap ipasok sa 1st gear.if nasa 4rth gear naman siya maingay ang transmission.
Kaya ngdecide na lang kmi ni wifey na benta na lang namin kesa ipagawa pa. Kukuha na lang kmi ng brandnew wala pang sakit ng ulo.
Thanks for you reply sir.
- Sep 2011
- 90
August 16th, 2012 09:47 PM #403^
Thanks for your immendiate reply sir GTi.
Mahirap palang magchange ng engine lalo at wala kaming kilalang mabibilhan at reputable shop na gagawa.
Kaya benta na lang namin yong Revo t kuha na lang ng brandnew.
- Feb 2011
- 17
August 19th, 2012 03:13 AM #404Hello po. Bago lang po ako dito sa forum na ito nakita ko po 2 days ago. Buti may forum para sa Revo owners and active pa yung mga members at dumadagdag pa.
Anyways, May few questions lang po ako. Sana po masagot niyo.)
Yung Revo po namin pala is a 2002 Sr 2c diesel with 118T+km
1. Nung mga naglagpas 100T km, tuwing cold start sa umaga may tumutunog sa makina na "Tok-Tok-Tok". Yung sabi ng mekaniko namin eh baka daw injection pump na barado na iyon. Totoo po kaya iyon? And if in case totoo po, Mga magkano po kaya pa repair nuon at san po may reputable shop na pwede?
2. Also pagkalagpas ng 100T km, yung speedometer nanginginig starting 20km/h until 60 km/h. Eh nung dati naman po di naman po ganun. Di din po matukoy ng mekaniko namin yung sira. Ano po kaya ang probable cause nuon?
3. Wise ba kung gagamit ng additional grounding kit at voltage regulator sa 2c engine? Totoo po ba na mag iimprove yung electronics at sabi din po na iba na may dagdag 5HP din daw po iyon?
4. San po pala makakabili ng schackles or lifters? Sabi po ng mekaniko namin, pag lifter daw ang ginamit eh lilikot yung likod? Totoo po ba iyon?
Sana po may makasagot nung mga questions ko. Gusto ko po kasi ipreserve at lalo pa pagandahin yung Revo namin. Thank you po sa magrereply.
- Apr 2008
- 6,235
August 21st, 2012 12:15 AM #405Yung diesel na Revo 2L engine ang gamit. 2C ang diesel engine ng Tamaraw FX.
2001 GLX diesel ang amin, currently with 94tkms on the clock. Some of your problems I have not personally encountered yet but I'll try my best to answer your questions.
1. I suggest you first have a thorough oil change and clean or replace the oil and air filters. If the problem persists try calibration.
2. Nanginginig din yung speedometer ko but that is because it was already replaced with a replacement unit. The old one does vibrate at high speeds, most noticeably at 4th gear. I believe that is due to the rather heavy vibration of the engine affecting the speedometer needle.
3. I'm not familiar with this, but the 2L engine has very minimal electronics, so there's little to fiddle with that. You're better off installing an aftermarket air filter instead.
4. You're going to lift the Revo? Again I have little knowledge in this matter since we normally keep everything stock. If your target height increase isn't very much, I'd suggest bigger wheels and tires instead.
August 21st, 2012 09:46 PM #4061. Nung mga naglagpas 100T km, tuwing cold start sa umaga may tumutunog sa makina na "Tok-Tok-Tok". Yung sabi ng mekaniko namin eh baka daw injection pump na barado na iyon. Totoo po kaya iyon? And if in case totoo po, Mga magkano po kaya pa repair nuon at san po may reputable shop na pwede?
- Feb 2011
- 17
August 22nd, 2012 01:04 AM #407*GTi,
Ah. Pagkaresearch ko po kasi sa wiki 2c napansin ko. haha. Anyways, Thank you for your reply.I'll try to test first what you have suggested. Gusto ko lang po sana na pataasan kaunti yung likod kasi more on heavy duty po yung revo namin eh. Most of the time medyo mabibigay yung karga. Eh para po kasing nakikita ko na baka sumayad na sa wheel well and baka may bumigay na parts.
- Feb 2011
- 17
August 22nd, 2012 01:11 AM #408*zap.FREEDOM,
Talaga po bang past 100T km nagiging ganun? Before kasi wala naman pong ganung tunog. Regarding the cluster gauges, pwede po ba yun na DIY or kailangan po dalhin sa specialist para mapalinis and matignan yung cable? Ganun po ba, kasi po kadalasan po heavy load yung dinadala nung revo tapos minsan po parang malapit na siya sa wheel well. ok lang po ba na ganun iyon?
- May 2011
- 5
August 22nd, 2012 09:35 AM #409good day mga sir,
ask ko lng po kung ano tumutunog s bandang harap na parang squick sound/ or parang mahinang pito. tuwing dadaan ako sa humps?at saan magandang magpagawa? badang mayon qc. po ako
revo 2002 vx200 gas poyun sa amin
thanks a lot sa reply
- Nov 2011
- 538
Tesla Philippines
