Results 51 to 53 of 53
- Feb 2009
- 102
November 2nd, 2016 11:54 AM #51Hi Mga Sir.
Car is Rav 4 2001 4X4 M/T.
Parang wala sa timing, pag tinapakan yung gas pedal pa kadyot kadyot ang andar. bagong palit ang fuel filter bagong linis din ang buong throttle body.
Pinalitan din namin mga spark-plugs at mga ignition coil, air filter.
Pag naka neutral at tinapakan ang gas pedal ok naman ang andar walang palya or delay. pero pag may load na usually 1st and 2nd gear pa kadyot kadyot na ang andar.
Ano kaya posible na pwede ko pa pa check. bagong palit din clutch.
Thank you mga Sir.
November 2nd, 2016 11:59 AM #52
Sir pinalitan din ba ung kung saan ng connect ung ignition coil mo? Also happens to my aveo kadyot kadyot din. Napalitan ko spark plug, high tension wires etc. Yun lang pala palitan then ok na.unless baka bara bara pagkalinis ng throttle body po.
Sent from my SM-N910G using Tsikot Forums mobile app
- Jan 2024
- 3
January 22nd, 2024 11:59 AM #53Mayron ba katumbas ng Rav4World sa Pinas? Wala ako makausap na fellow Rav4 owners sa sarili kong bansa. Ok naman sa Rav4 world, dami ko na nga post dun at somehow friends pero siyermpre kung may katumbas sa pinas mas okay. Marami kasi difference: terrain, climate, driving conditions, culture so most of the time I have to convert to US standards to get the best responses from Rav4 World, ex i convert kmpl to us mpg, km to miles para lang mas mag relate sila.
So Mayron ba katumbas ng Rav4World sa Pinas, gaya nito Toyota RAV4 Forums
