Results 1,251 to 1,260 of 1455
November 12th, 2010 11:34 PM #1251
Synthetic oil vs. conventional mineral oil
The advantage of synthetic oil is that it can withstand higher temperature and can work longer without losing its lubricating qualities. It doesn't get thicker at below-zero temperatures providing good engine lubrication at a cold start. However, since it's more "thinner" a high-mileage engine filled with synthetic oil will more likely to develop leaks and you will more likely to hear lifters tapping noise at a start. Therefore, If you have low mileage or turbo engine and driving under heavy conditions such as high temperature, excessive load, long intervals without an oil change, etc., or simply want to provide extra protection for your engine, synthetic oil may be a good solution. But I don't think it's worth to use synthetic oil in high-mileage engines - thicker mineral oil will provide better protection as long as you change it regularly.
I tried using synthetic oil before but reverted back to ordinary oil since 10K km takes me about a year to reach. If you use your car in extreme conditions better to use synthetic but for normal driving conditions mineral will do. mas maganda din ang more frequent change oil than 1X a year change oil. but if you have money to spend you can go for synthetic. some even change oil every 3k km only.
November 12th, 2010 11:54 PM #1252
Some clarifications lang sir Ginnova. When you say high mileage engine, do you mean old engines that already have a high mileage reading? Since mine is fairly new, is this considered as a low mileage engine pa? Also, what does extreme conditions mean? My innova is used daily for commute to work (around 40km back and forth), mostly on the expressway. Then maybe family weekend family trips to the mall. I would say the 10km would be reached in 6-8 months.
November 13th, 2010 12:46 AM #1253
Friends,
At last, I got my Innova! I drive it from Toyota Cubao to Navotas. Wow, what an experience! The climate control is truly a nice addition to it. It just take less than two weeks to wait. Nice Sales Agent named Jaja Santiago. So accomodating. Can't wait till tomorrow to drive it again to work. Three days before delivery, I can't sleep. Now its here, I can't also sleep!
- Oct 2009
- 182
November 13th, 2010 01:40 AM #1254
- Jun 2006
- 1,139
November 13th, 2010 02:14 AM #1255advantage talaga ang climate control pag malamig ang outside temp at sipunin pag nalamigan ang mga bata.
- Jun 2010
- 79
November 13th, 2010 03:28 AM #1256
- Sep 2009
- 8
November 13th, 2010 04:57 AM #1257
November 13th, 2010 06:35 AM #1258
Hi guys,
Safe na ba bumili ng diesel na variant? or may risk pa din na magloko?
November 13th, 2010 07:46 AM #1259
- Oct 2010
- 39
November 13th, 2010 07:47 AM #1260
