Page 9 of 1548 FirstFirst ... 56789101112131959109 ... LastLast
Results 81 to 90 of 15472
    #81
    Share lang mga tol..
    ok lang ba patakbo ka 3rd gear 100kph with 4000rpm?
    Nakibaghabolan ako sa 3.0fortuner sobrang nahirapan ako pero kinaya parin ng innova natin.. naiwan ko siya., with 140kph...
    Sakin di pa rin nasolve ung tunog sa baba ng manobela.. everytime my lubak..
    pina ayos kona sa casa ung pedal na palitan na ng bossing ba yun??
    but still now my tunog pa rin pero di na masyado.. anu kaya un?? nakakainis..!! pa check ko uli sa casa pah 20k pms ko...
    #82
    Quote Originally Posted by morlack View Post
    Sir i think ok lang yan wag lang siguro palagi. tried it once sa stop light, may iniwanan akong van pagdating ng stop light tumabi sakin tapos sabay bomba nung nag green npa abot ko 2nd gear ng 60kph.hehe iwan siya. pero mafeel mo tlga na sisipol na tlga engine mo.
    Jun 2008
    #83
    Last Monday on the parking lot, my Friends Innova G door's won't open via remote...even if the LED on the remote is "blinking" when you try to press it. Next, we went home and got the "spare" key thinking maybe the battery on the remote is "weak". When we returned and tried the spare key...it STILL... won't work? What he did was open the door directly using the key...then the alarm sounded...he immediately inserted the key in the ignition and started the car...the "sound" from the alarm stopped. The car is just 14 months old...
    Aug 2009
    #84
    Toyota recalls over 65,000 units of Innova and Fortuner--in Vietnam
    27 Apr 2011 Printer-Friendly Version
    Toyota Vietnam is recalling 65,703 units of its locally-assembled Fortuner sport-utility vehicle and Innova Asian-utility vehicle nearly a month after the Japanese carmaker made a similar announcement involving a much lower number of vehicles.
    In March, Toyota announced a recall for only 8,830 units of the said models.
    Toyota engineer Le Van Tach, however, disputed Toyota's initial report and estimated that as much as 60,000 units could be affected, ThanNienNews.com reported. The latest announcement, which involves more than 65,000 vehicles, was made on April 15.
    According to Toyota, Vietnam-made Fortuner and Innova units were found to have either over-responsive brake systems, or improperly-mounted camber bolts and seats.
    ThanNienNews.com added that, though the recall is not the first in Vietnam, it is the largest ever made based on the official records of the Vietnam Register Agency, the government body responsible for checking vehicle quality. The agency is reportedly scheduled to inspect Toyota Vietnam's production facilities to find what had caused the flaws.
    Toyota Motor Philippines has yet to reply to TopGear.com.ph's query on how the recall would affect Thai-built Fortuners sold here. The Toyota Innova is assembled in the Philippines.
    #85
    Quote Originally Posted by jbs View Post
    The move came two weeks after the company first admitted to three flaws in Innova models. It said some cars released to the market had over-responsive braking systems while other had improperly mounted camber bolts and seats
    There were only 2 mentioned flaws. What's the 3rd one?
    - over responsive braking - wheel lock, nonsense abs?
    - improperly mounted camber bolts and seats? - tire wear, handling, kabig?
    Jan 2010
    #86
    To all Innova VVTi A/T bros.
    Napansin ko lang na parang mataas ang RPM ng Innova namin while driving. Parang naiingayan tuloy ako, hehehe.
    I dont know if this is psychological pero parang mas umingay cya compared before.
    Normal lang ba na umabot ng 2K ang RPM kahit nasa 40kph plang, being light footed sa gas peal?
    Thanks
    May 2005
    #87
    Quote Originally Posted by ericson21 View Post
    thanks for the info sir.
    sana nga drain out lang ang battery pag ganun, hindi mag li-leak ang battery.
    may na experience ako eh. pinatay ko engine ko kasi nakarating na ako dito sa bahay, nag unlock lahat ng doors kasi pinatay ko engine diba. eh naglagay ako sunshade sa windshield ko, nag auto lock yung doors, hinayaan ko lang kahit nasa loob pa ako. pag bukas ko nag alarm innova ko. ganun ba talaga? hehe. ngayon ko lang na experience yun kasi. me naka experience na po ba nito?
    thanks.
    On my Fortuner '06, it is normal for the door locks (provided that they are lock) to unlock immediately after shutting off the engine by turning the key to "off"
    What it does not do is to automatically lock the doors and activate the alarm after what happens as stated in the first paragraph.
    The only instance that the alarm system will reactivate without intervention is when you disarm the TVSS but no doors were opened for at least 1 min. from disarm. In this instance, the TVSS/alarm will reactivate on its own without any intervention from the you and the key fob.
    May 2007
    #88
    Quote Originally Posted by rb1_fernandez View Post
    it might have something to do with radio frequency interference in the area... it happens to me sometimes, especially when i'm in the Ortigas area near Big Berts's.
    May 2007
    #89
    Quote Originally Posted by spyghost View Post
    how do you mount the stepboards? binubutasan ba to? or merong nang abang na mga mounting?
    AFAIK, may mounting na kasama ito at iniscrew na lang sa may chassis.
    #90
    Quote Originally Posted by Louie_18 View Post
    Thanks
    Never ko pa naranasan ang 2k rpm sa 40kph unless binigla ko then di ko binitawan ang gas pedal tapos inclined road pa . try releasing the gas pedal then press it gently again mapapansin mo bababa ang rpm to 1.25k-1.5k rpm depende sa road inclined.
    Aabot din ng 2k rpm if you're using 3 or 2 dapat always D gamit mo sa AT.
    Hirap kontrolin ang RPM ng AT kaya mas malakas kumain ng gas .
    Pansin ko pag 2k rpm sa AT mga 1.5k rpm lang sa MT sa tamang gear.
    pero mas comfortable ako sa pag drive ng AT. Depende sa kasanayan. Nasanay lang ako sa AT since my Innova is AT.
    Pls let me know kung may adjustment ang Casa about rpm sa AT
Toyota Innova Owners & Discussions [continued 3]
