Results 15,371 to 15,380 of 15472
- Sep 2021
- 872
June 15th, 2024 01:06 PM #15371^^^
Ah yes, I remember nauso din yang Solex locks in the 90's, a lot of the accessory stores in Banawe had them.
They fell out of favor when people realized that car doors are mechanically easy to open, regardless of lock mechanism. I saw one guy in Banawe simply use a long wire once para hugutin yung mechanism. A less refined way would be to simply break a glass panel and reach in.
- 53,883
June 15th, 2024 09:28 PM #15372
- 53,883
June 15th, 2024 09:30 PM #15373
- Oct 2006
- 6,091
June 16th, 2024 09:25 AM #15374The Honda Civic EG door lock was easy to bypass using a wire coat hanger or GI wire bent into a hook. Well most 80s - 90s cars used the same door lock panel design. I remember getting on a Corolla Big body taxi with holes drilled through the all 4 door lock actuators. I asked the driver, he said it was to make opening the doors easier in case he left the keys inside.
- 53,883
June 16th, 2024 09:30 AM #15375
- Nov 2019
- 1,239
June 17th, 2024 12:18 AM #15376Eto nalang gawin, kunin starter relay at fuse pump habang ginagawa pa yung key fobs.
https://www.youtube.com/watch?v=M26o...Noah%27sGarage
Pero if maalam magnanakaw, magbaon na yan ng relays just in case Innova talaga yung target.
June 17th, 2024 11:42 AM #15377
Uso pa ba nakaw-gulong on Innovas or other similar designs with the spare tire under the chassis? I know it's a lottery, but statistically... is it still a major concern today?
When I bought my previous Innova in 2015, spare tire thefts were a bit more common. Sabi nila (whether true or scare tactic lang to get you to buy a lock), sisipain lang daw yung spare tire into submission and it will literally come lose from its carrier so I had a lock installed from the factory. Nowadays... in fact, at least in the last 6-8 years, wala na akong nababalitaan.
- 53,883
June 17th, 2024 12:10 PM #15378
- Jul 2024
- 15
July 5th, 2024 07:57 AM #15379Good day Tsikoteers. I have Innova 2013 G D A/T with 85K odo. May recurring unusual noise galing sa dash board tapat ng passenger side. Parang tunog ng fan na may tinatamaan na lata. It usually starts when the gear is engaged and stops when the speed gets pass 40kph. Pag high speed sa highway, nawawala, pero pag bababa yung speed to less than 40kph tutunog nanaman. Pagnaka neutral or Park nawawala din.
May nakakaalam ba or nakaexperience kung ano cause nito? TIA.
- 53,883
July 5th, 2024 08:21 AM #15380
Tesla Philippines
