Page 1410 of 1548 FirstFirst ... 131013601400140614071408140914101411141214131414142014601510 ... LastLast
Results 14,091 to 14,100 of 15472
    Apr 2010
    #14091
    Quote Originally Posted by mumuy View Post
    Hi sir,
    What is the size of sd card for 2019 innova car stereo gps slot?
    Not sure, either full size SD or Micro SD ang common for the GPS slot
    Sep 2008
    #14092
    Quote Originally Posted by ParticleX View Post
    Hi again sir,
    Can you post a picture of the type of card used? Do you use any adapter?
    Oct 2018
    #14093
    Quote Originally Posted by aqgvjr View Post
    Good afternoon!
    Gusto ko sana mag upgrade ng headlight bulbs to LED. Kailangan ko po mas maliwanag na ilaw para sa biyahe. lalo na pag umuulan. ano po ba socket ng innova 2008?
    Ok po ba yun LED?
    Slamat po!
    Be careful of buying cheap LEDs as they can cause problems with your wiring or can even be less bright than your stock halogens.
    I recommend Philips Ultinon Essential for an entry-level, budget-friendly LED. Though if you have the budget, you can go get Philips X-treme Ultinon or PIAA LEDs. These all actually use only a fraction of the wattage of the bulbs they replace and have drivers included so your wirings should be safe (so long as they are genuine). Your Innova model should use an H4 bulb. Though these emit white light at 6000K, so your mileage will vary when used in the rain.
    Don't even think about getting LEDs that use Cree chips, be it an XHP50, XHP70, or whatever they call it. These produce a lot of glare even in lowbeam if used in a reflector bowl headlight which is dangerous to oncoming traffic. You don't want to be the cause of an accident.
    Oct 2018
    #14094
    Meron po ba sila para sa lahat ng interior lighting? salamat!
    Meron naman. Though yung one-side LED lang kinuha ko sa kanila. The rest ng gamit ko sa interior Philips and Osram brand.
    They have good reviews sa mga products nila kaya safe gamitin and durable naman. Not to mention maliwanag na maliwanag.
    Apr 2010
    #14095
    Hi again sir,
    Ours is a 2016 pero it is the first gen with the 2.5 2KD engine, so most likely different ang head units natin. I am using a full size SD card in the stock AVT head unit.
    Dec 2011
    #14096
    Good afternoon!
    Ok po ba yun LED?
    Slamat po!
    For LED headlight:
    1. Make sure po projector lalagyan nyo, at may good cutoff. If reflector housing, you will cause glare sa kasalubong nyo, masakit po LED sa mata.
    2. Don’t go with 6000K or higher sa lowbeams . Sa akin di maganda 6000K LED sa asphalt, fogs, and heavy rain (byaheng buda, davao with 35% medium tint) - kahit may yellowish foglamps pa. Go with a 4300K or all-weather color temperature.
    3. Lumen values ay overrated karamihan, go with Lux values pero sadly “not advertised” po ito.
    4. As applicable, make sure canbus-ready po ang LED headlight (or know if your car is using canbus) or you will get error pag start car. We have a Ford Ranger Wildtrak and I’m very careful dahil sensitive po sa electronics and etc. Buti nalang our Innova is not. [emoji28]
    Since nakabili na po ako (impulse buy) ng 6000K LED, I paired it with an Osram Night Breaker Unlimited sa left and yung LED sa right lowbeam. [emoji74][emoji594]
    Jun 2005
    #14097
    Quote Originally Posted by tuks View Post
    For LED headlight:
    Anong year innova mo? Yung current model innov tinotoyo kapag nagpapalit ng brake lights eh. Dont know about headlights though
    Sent from my MI MAX 2 using Tapatalk
    #14098
    Quote Originally Posted by sirkosero View Post
    kindly explain, po.
    Jan 2009
    #14099
    kindly explain, po.
    CAN Bus error malamang.
    There might be some sort of warning displayed on the dashboard if the bulb is busted, missing, or replaced with non-CAN Bus friendly LED bulb.
    Oct 2018
    #14100
    I experienced this too with our Touring Sport. Palitan ko sana ng Osram red LED para sa rear combination lights (W21/5W). Nung nilagay ko it's either yung taillight lang ang gusto sumindi or yung brake light, but not both. Kahit pagbali-baliktarin pa ang pagkalagay hindi mapapaandar ng maayos. Akala ko ako lang may problema.
Toyota Innova Owners & Discussions [continued 3]
