Results 71 to 80 of 13229
BANNED BANNED BANNED
- Oct 2004
- 128
March 8th, 2005 12:42 PM #71I would highly recommend the innova....parang gas kung humataw yung diesel...and minsan makakalimutan mo na diesel pala dala mo kasi medyo quiet yung engine. maganda yung ride nya....parang kotse na...hindi bouncy ang ride unlike the fx. maganda pa yung dashboard. quite elegant for its class.
I have a brother who has a crosswind. after driving my innova , inggit na inggit sya baka ibenta nya crosswind hehehe
March 8th, 2005 12:50 PM #72
How about the rear suspension? Since it doesn't use leaf springs will it buttom out easily if you carry heavy loads?
March 8th, 2005 12:53 PM #73
Originally Posted by geo
baka para na ring gas lumaklak ng crudo?
- Oct 2004
- 110
March 8th, 2005 01:21 PM #74Originally Posted by ILuvDetailing
on our way home from tagaytay, dumaaan muna kami ng mariwasa to purchase 50 pcs of floor tiles (60cm x 60cm) plus its load of 5 adults (90 lbs to 150 lbs) and two kids, masasabi ko na oks ang suspension ng innova.
March 8th, 2005 01:32 PM #75
Originally Posted by boybi
Masyadong matakaw ang 4km/litre na fuel consumption. The lancer evolution 8 that has 280hp has almost the same consumption. ang d4d only has 105hp tapos diesel pa.
Siguro sanay siya mag drive ng gas powered car. I noticed that people who are used to driving cars when given the chance to drive a diesel they have the bad habit of squeezing the gas too much. I mean 1st gear pinapaabot ng 20kph, 2nd gear pinapaabot ng 40kph. (3500rpm) parang mga friends ko nung pinadrive ko ung L200 namin.
If it is a civic parang pinaabot mo palagi ang 1st gear sa 40kph while 2nd gear parang 70kph.
Ease up on the gas let the automatic transmission switch from lower gears to higher gears at 2000-2500rpm. Ung iba ginagawa dahil naiinip binibirit ung gas pedal. Remember you bought a diesel talagang pasensya ang kailangan nyo.
Kung ako tatanongin nyo 1st gear 15kph 2nd gear 30kph 3rd 45kph 4th 55kph then 5th. Try it youll see the difference.
March 8th, 2005 08:49 PM #76
saw the Innova this afternoon up-close. some of my observations:
medyo masikip nga yun 3rd row seats.
yung clearance ng rear wheels sa wheelwell, more than double ng sa harap. medyo pangit tingnan.
also, for manual transmissions, the clutch and the brakes share the same brake fluid reservoir.
ang daming naglabas ng new innova dito sa amin, nagkalat sa daan!Signature
March 8th, 2005 10:54 PM #77
anu maganda or ok engine oil para D4D, yung orinary or synthethic?? is it true na you can skip 5k PMS change oil if you use synthetic?? mag how much diff ng ord. and synt oil change sa casa?? need inputs pls...
WBR,
March 8th, 2005 10:59 PM #78
Pakana lang ng CASA yung you can extend your interval if you use synth. They are trying to justify the price kasi.
Pero if you change your oil every 5k, ok na ang mineral based. Hindi ka naman kumakarera or naka-high speed maghapon.
Even in the daily grind of traffic, mineral-based oils will hold up pretty well.
Tsikot Member Rank 3
- Sep 2003
- 786
March 8th, 2005 11:08 PM #79bros, got my second reading na, 9.8km/L., combination of slight traffic and e-ways. ganda nga tumakbo, but I limit my speed to 80km/h muna. Baka kasi di ma break-in ng maiigi. Had the undercoat done in shell with 3M. Suspension is great at 4 adults and 2 kids. Bro Innova Boy, ano ang latest sa iyo?
March 8th, 2005 11:08 PM #80
thanks Otep, pero is it advisable ba talaga, cause heard from friends na mas maganda ang perfromance ng engine if using synthetic oils.. mas mabilis pa daw ang hataw??
Tesla Philippines
