Results 451 to 460 of 559
- Jul 2013
- 7
July 22nd, 2013 10:02 PM #451Thank you, Mile2 for that quick reply. You have been so helpful, as always
So my case is the same as yours? I want to believe that at first. But dear, I really heard that hit for it was quite loud. If you say that it was not caused by the stone, what has triggered that sound? My presumption, if I may say, and correct me if I am wrong, is that, the pressure of the hit made a crack in that most vulnerable portion of the gas tank (my speed was 100kph that time). And there was no warped part anywhere, just a crack about 2 inches.
Of course not, Mile2! I only have it done once. And yes, after 5 days, the leak was back. At least, I made you smileI have not driven my innova for two weeks already. I would love to follow your advise as soon as the leak is gone. Would you believe, if the weather is cold, there is no leak. And each time the sun shines, the leak is back. Grrrrhh!
About the charcoal and filler cap, do I really have to replaced them agad-agad? hehhehe
- Jul 2013
- 7
BANNED BANNED BANNED
- Feb 2013
- 487
July 22nd, 2013 10:12 PM #453It is the filler cap that regulates the pressure of the tank, the function of the charcoal canister is to avoid the venting of gasoline into the atmosphere.
Nag warp na yung tank mo habang tumatakbo ka, then dahil sa stress sa bakal nagkabutas na at yung narinig mo na sound ay yung sudden release of pressure at pag balik ng tank sa original shape.
- Jul 2013
- 7
July 22nd, 2013 10:25 PM #454Hi Sio! Thanks again for your quick reply. Di nga? Ganon ba yon? It could happen while driving? Truly? Only the filler cap must be replaced? That would be such a relief. Haaayyyy!
Anyone would dispute Sio? What do you think Mile2? Wow, this is good... battle of the brains, hehehhe
- Feb 2013
- 487
July 22nd, 2013 10:31 PM #455Kailangan mo rin palitan yung gas tank mo, may butas na yan. For the charcoal canister, wag mo na palitan.
It happened lang na nagpalit sila before nung canister kasi di rin pa nila mahanap yung source ng problem, di ko idea yung filler cap, based lang yung sa mga nabasa ko rin sa post ni Mile2 and yung ibang members na nagkaroon ng same problem rin.
Nung di pa ako nagpapalit ng filler cap, kapag binuksan mo yung tanke, pahigop yung pressure, so ibig sabihin may vacuum sa loob, nung nagpalit na ako, yung pressure is palabas.
- Jul 2013
- 7
July 22nd, 2013 10:38 PM #456Sio naman, bakit dapat na palitan yung gas tank? Wada pa ako, hehehe. Sabi ni Mile2, welding lang okey na. Nalito ako ulit, dear. Reply saken kanina ni Mile2, parehas palitan, Tapos ikaw, sabi mo filler cap lang na ang basis mo yung post din ni Mile2. Sana nga yung cap na lang para mas mura ang gastos ko, hehehe. Thank you, Sio!
July 22nd, 2013 11:32 PM #457
What model pala ang Innova natin sir? mine is 2005... ano pala ang pinalit mong filler cap yung bagong model or old pa rin?
Ipa repair mo muna ang Gas tank sir then try to change the filler cap first then observed... silip mo gas tank mo kung nag wawarp after driving. kung nag wawarp pa rin then it's time to change the charcoal canister.Last edited by kristine123; July 22nd, 2013 at 11:37 PM.
- Feb 2013
- 487
July 22nd, 2013 11:38 PM #458Yung bago ng filler cap ang nilagay ko, yung malalaki ang butas, same na with the filler cap of diesel variants.
2008 Innova E.
- Jul 2013
- 7
July 23rd, 2013 08:26 AM #459*kristine123
Hi! Thank you for your reply. Mine is 2006 M/T. Wala pa ako pinapalitan kahit anong major parts. Wala rin ako nadidinig na kahit anong awkward sound, just like what you guys experienced. My innova ran as smoothly as when it was first bought, up until that day when I heard that sound while driving along north expressway.
Girl, sige sundin ko muna advise mo. Yung ginawa mo dun sa filler cap mo, nadali mo ha? Hindi yun nagawa ng ibang guys dito kaya napabilib mo sila, hehehe.
Regarding dun sa warping, sige gawin ko rin yung silip-silip na yan sa ilalim. I hope yung filler cap lang talaga ang problema at hindi yung charcoal canister.
Thanks again, kristine123.
- Jul 2013
- 7
July 23rd, 2013 08:31 AM #460*siopaonatoasted
Hi sio! Sige palitan ko na yung filler cap, tutal 7 years na rin naman. Tignan natin anong sasabihin ng SA ng Toyota pag yung ibang model ang bibilhin ko. Update ko kayo.
Thanks again, sio!
Tesla Philippines
