Results 11 to 20 of 500
- 290
February 21st, 2003 02:40 PM #11when (odo reading or year) kayo nagkaroon ng mga major problems sa rolla nyo like problem ng mga sumusunod:
1. ignition system (starter, distributor, etc)
2. cooling system (radiator, water pump, fan, etc)
3. a/c system (compressor, drier, expansion valve, condenser, aux fan, etc)
4. alternator
5. transmission
6. clutch
7. engine
8. steering ( rack and pinion, pump, hose)
9. suspension
others.
yung akin, 95 rolla gli and now at 100,000 km/8 years, ang mga napalitan na ay:
timing belt (including tensioner and oil seals) - 95,000 km/~8yrs
clutch assembly & drive shaft oil seals(indluing tranny support) - 98,000km/~8yrs
evaporator - 50,000 km/~5yrs
rear struts - 48,000km/~4.5 yrs
front and rear engine supports - ~after 5.5 years
tie rods, ball joint - after 6 years
rack and pinion leak - hindi pa napapaayos more than 1.5 years (narepair na rin ang hose mga after 6.5 years)
yung sa inyo ano na? this will be good at least we have data of some sort of when to expect failure. heheh depende pa rin sa gamit di ba? pero para may idea tayo. makikita din natin common failures ng mga rolla natin.
February 21st, 2003 03:41 PM #12
94 yung akin, 102k odo na
Item:
1) Wala pa
2) 2000... Cracked radiator top
3) 99-2001... faulty compressor, worn out aux fan.
4) 2000... fault of mechanic, shorted my battery, fried my IC. 2002... fault of mine, forgot to cover alternator while cleaning engine, rusted my diodes.
5) Tranny... 99 replaced clutch disc, pressure plate and tensioner... again nung 2002 (replacement parts lang kasi)
6) Engine... Wala naman except sa punit na goma sa high tension wire. Maintenance yung timing belt, oil seals, tensioner etc at 86K odo.. Engine support din nga pala.
7) Steering... Power steering leak 2001, replaced hose and rack and pinion repair kit.
8) Suspension... hanggang ngayon hehe.
February 21st, 2003 04:24 PM #13
We used to have 92 GLi.
1. Never had a problem with this part.
2. Like theveed, cracked top, then changed the whole radiator to 3 rows for more cooling effect, changed water pump (I used the water pump from Corona 3S-G3 engine) Year: 2001
3. Aside from annual cleaning, busted freon hose crimps Year: 1999. Thermostat diode Year: 1998
4. Never had a problem with this part.
5. Never had a problem with this part.
6. Replaced clutch disc, clutch release bearing, & pressure plate Year: 2000.
7. Replaced timing belt, idler pulley and tensioner at 78,000kms. Everything else was left bone stock. Except for re-adjusted tuppets. Year: 2000
8. P/S hose burst, caused damage to P/S pump. Changed everything to new OEM parts and specs. Year: 2000
9. Still running the original bushings & shocks up to the next owner which is one of our relatives.
- 290
February 21st, 2003 06:32 PM #14halos pare-pareho din pala talaga and common yung power steering leak pero mukhang mas maaga bumigay yung sa akin.
mga rolla peeps keep them coming.
February 24th, 2003 05:07 AM #16
My 95 Corolla 1.6L
1. ignition system (starter, distributor, etc) - palit ako ng starter during 90K miles
2. cooling system (radiator, water pump, fan, etc) - coolant flush lang during 59K miles
3. a/c system (compressor, drier, expansion valve, condenser, aux fan, etc) - orig pa
4. alternator -palit ako ng alternator during 69K miles
5. transmission - original pa
6. clutch - original pa
7. engine - timing belt and valve cover gasket replacement at 60K miles, replaced oem battery during 55K miles
8. steering ( rack and pinion, pump, hose) - original pa
9. suspension - original pa
10. Others - replace light bulb for busted headlight and tailight
- 290
February 24th, 2003 02:30 PM #17bossing roydok, not bad for your friend.
sir visitor, swerte din hindi pa leak ang steering system pero maaga yata yung alternator. hmmmm kailangan ko na kaya maghanda ng budget para sa alternator? yung cooling system naman ay parehas tayo na oks pa pero nagflush ako last week at yun nagleak doon mismo sa drain plug. lagay na lang ako ng teflon tape ngayon at medyo nabawasan leak after that then ngayon wala na akong makitang leak, settle na siguro yung mga sediments ulit kaya nabarahan na yung leak.
February 24th, 2003 05:58 PM #18
to zildjian,
yun corolla ko assembled sa U.S. if i'm not mistaken if not in Iowa plant maybe sa Kentucky plant, the reason why maaga nasira yung alternator is beacause the U.S. made corolla has an AC Delco starter and AC Delco Alternator, and AC Delco is a GM part :evil:, kaya yun nasira alternator and starter ko i didn't think twice to replace it with a DENSO part pero remanufactured lang mahal brand new e!
March 2nd, 2003 11:07 AM #19
sa 94 Corolla GLi ko, 108tkm na, I already replaced d front and rear shocks wid Kayaba Gas, replaced also d front tie rod, rack end, stablink bushings and rear stablink. ngayong hassle free na...... :mrgreen:
- 11
May 6th, 2003 02:19 PM #20HI Guys!
just want to ask if the AE 101 corolla is thesame thing with Toyota XE or GLI, I'm just looking for 2nd hand sedan with a budget of 200K kasi.
Sorry for stupid question! I dont have any idea kasi with cars at this time maybe until I have one.
Thanks
Tesla Philippines
