Results 5,481 to 5,490 of 5533
August 14th, 2024 03:20 PM #5481
August 14th, 2024 03:28 PM #5482
August 14th, 2024 03:43 PM #5483
Squealing brakes could mean that brakepads are thin and need to be replaced ...
August 14th, 2024 04:49 PM #5484
easy lang iyan bro. i cleaned mine earlier this year. bili ka lang ng crc maf cleaner spray na 190 ml para di sayang. meron iyan sa lazada or shopee. iyong 400 ml na available sa mga hardware stores malaki masyado baka ma-tengga lang.
nung nagpalit din ako ng air intake hose dapat sinabay ko na din linis ng throttle body kaso hindi ka na anticipate na accessible na din pala iyon sa process ng pagpalit. kung alam ko lang bumili muna sana ako ng crc tb cleaner. ang mahirap lang mag loosen ng bolts. pero w/ the help of wd 40 and then leaving it doused overnight, it should be an easy enough nudge the following day.Last edited by baludoy; August 14th, 2024 at 05:58 PM.
August 14th, 2024 07:08 PM #5486
Napipikon ako sa casa. Lakas mangoyo
Is it correct na I will have the ff removed:
Injector Cleaner
X1R Engine Treatment
Engine Wash
Aircon Cleaning
I requested to replace the wipers talaga. Do I need the brake cleaner pa?
Sent from my SM-N960F using TapatalkLast edited by _Cathy_; August 14th, 2024 at 07:59 PM.
- 53,883
August 14th, 2024 07:37 PM #5487it's probably worn suspension components.
yes, it's highway robbery, as they won't be connecting any expensive diagnostic tool to your car.
sisilipin lang nila ang suspension, yugyugyuin here and there, to see what's loose.
i bring mine to the banawe boys, as i have faith in them.
as i recall, i think i spend less than 3500 bucks there, when i had my driver side a-arm replaced.
August 14th, 2024 09:34 PM #5488
Every car person knows that engine washes are not a good idea ... after they do engine wash ... they're going to let your engine idle for at least 30 minutes ... so the water in crevices evaporates ...
Remove brake cleaner as well ... yeah, it's necessary in certain cases ... but there is no guarantee that dealer will perform brake cleaning ... better to have this done outside ...
- 53,883
August 14th, 2024 10:14 PM #5489
August 14th, 2024 11:22 PM #5490
Fasten your seatbelt! Or else...Driven To Thrill!
