Page 268 of 554 FirstFirst ... 168218258264265266267268269270271272278318368 ... LastLast
Results 2,671 to 2,680 of 5533
    Aug 2012
    #2671
    You might be suffering from engine knock. What fuel are you using?
    ganun ba yun kapag engine knock kahit on idle wala naman or higher gear/speed? yun kasi yung sumayad yung kotse ko na galit na galit ako. so naka floor lang ako lagi sa throttle on 1-3 gear then nung paaproach na ako sa lilikuan ko naririnig ko kaso sobra hina lang need off ang radio. check ko dipstick ko and oil was ok. pacheck ko kaya? btw xtra advance gamit ko na gas 93 octane ata yun di ko sure,
    #2672
    Quote Originally Posted by i'm CARLOver View Post
    Yup. Engine knocks are usually evident only when the engine is stressed (i.e. hard acceleration).
    Instead of bringing it to your dealer, why not try other fuel brands first? Yun lang din naman sasabihin nila, na magpalit ka ng fuel.
    Mar 2015
    #2673
    Quote Originally Posted by timo07 View Post
    Seriously, sumasakit ang kaliwang tuhod ko after driving at least an hour in heavy traffic. Tumatanda na rin yata or tumitigas na itong clutch ng kotse ko ngayon. Baka 2nd week of july maideliver na. Not sure lang kung nakarehistro na so baka di ko pa rin magamit.
    Sana earlier ma-deliver haha! Yung sakin sir a week after I got the unit dun palang nila ni-register, and then a week after ulit, plates naman. You can use the car naman sir, you have 7 days free pass. Then dapat mabigay nila OR/CR mo before matapos yung 7 days upon purhcase para good to go ka na talaga.
    Aug 2012
    #2674
    ok sir try ko pakingan ulit mamaya at paubos na rin gas ko, try ko naman pakargahan sa shell yung v power nitro plus nila. thanks sir
    #2675
    Try a different gasoline brand. Per my experience with Petron on my Altis, i also get engine knock with their 93 octane.
    Nov 2011
    #2676
    Meron na bang nakapagpakabit sa inyo ng spoiler for 11th gen? Yung parang katulad sa 2.0v? I own kasi yung 1.6v tapos pearl white parang ang pogi kasi pag may spoiler nasa magkano kaya yung ganun(including installation)? Thanks!
    Aug 2012
    #2677
    ok sir will do try other brand. baka lang hindi maganda sa petron thanks sir
    #2678
    I'd suggest Shell, Total, and Caltex dahil yan lang yung mga multinational and they have stricter quality standards.
    Sep 2013
    #2679
    bro, correct me if I'm wrong here pls, I read somewhere in other threads that you mentioned all gasoline in pinas are same quality regardless either petron, shell, unioil etc... pagka-understand ko for example sa bottled water pareho lang yan tubig kahit pa ano pang brand nito. Hehe
    Mar 2015
    #2680
    Good morning sirs! Ask ko lang for those who do full tank fillups, when do you gas up? As soon as the low gas warning lights up, or do you rely on the cruising range distance? If the latter, sinasagad nyo ba til 10 or below before you fill up? TIA
Toyota Corolla 11th Generation Altis [Merged Threads]
