Page 545 of 554 FirstFirst ... 445495535541542543544545546547548549 ... LastLast
Results 5,441 to 5,450 of 5533
    Jun 2013
    #5441
    Time to change ATF ...
    Its CVTF, not ATF.
    I think its also the 3 or 4 years or 40k, which ever comes first.
    Oct 2009
    #5442
    Is 'bolt tightening' a standard part of the PMS? It is bundled with brake cleaning in Toyota Otis for my 45k PMS but I will be having it done elsewhere so I am just checking if I need to ask them to do this as well.
    #5443
    Quote Originally Posted by mousemouse View Post
    It's free
    #5444
    in my opinion,
    it's an "historical procedure", po,
    back when they made cars "the more traditional way".
    they probably chose not to remove it from the current literature, for justin, i.e., to cover the un-foreseen.
    anyway, no harm done if they do find a few loose bolts to tighten.
    one advantage of having the pms done in the casa, is that the mekanikos are well-versed with the nuances of that car.
    if one were to have the pms done elsewhere, the mechanics there might not be acquainted well enough with the car's "features".
    hey!
    just found out, this topic was already broached here, back in 2013...
    la lang.
    Oct 2009
    #5445
    thanks guys! i will just ask the shop i will use to do it. When I got my PMS done at the casa every 10k i get charged around 2k for the check up labor (they also clean the brakes), then every 5k i only get charged 1k for the labor + 2k for brake cleaning & bolt tightening.
    #5446
    Why is my fuel consumption like this?
    #5447
    you probably zeroed the km/li readout recently, thus canceling the previous higher km/li reading, and have since been driving short distance in slow or heavy traffic, or been idling.
    hopefully, if you press the buttons to show your average km/li, as well as your time lapsed, that should give you a better perspective in life.
    but you probably suspect that, already.
    hey! 44K km for a relatively "older car" is remarkable.
    the pre-owned 2015 altis i am driving now, has 36K km on the odometer.
    Mar 2004
    #5448
    Too much idling ...
    #5449
    Thanks, but yours has even lower mileage! Wow!
    Too much idling ...
    oh, you're right! I've been idling my car a lot this past month because my second Mom has been going with me when I do errands, but I only let her stay in the car. Most of the time I'd leave the car idling for 30 mins. I had no idea na ganyan pala kalakas sa gas idling!
    #5450
    sa 1.6L engine i think a liter or less per hour when idling
    https://youtu.be/dFImHhNwbJo?si=nBaSeFd42ihZ2ryX
    Sent from my SM-A736B using Tsikot Forums mobile app
Toyota Corolla 11th Generation Altis [Merged Threads]
