Page 319 of 358 FirstFirst ... 219269309315316317318319320321322323329 ... LastLast
Results 3,181 to 3,190 of 3575
    Jun 2018
    #3181
    Quote Originally Posted by chon961 View Post
    You can go for Semi- Synthetic oil, as long as you follow the proper oil change interval, which is 5,000 kilometers or 6 months maximum, whichever comes first.
    What year and model is your car?
    2010 Altis paps.
    Jun 2012
    #3182
    Good Afternoon Sirs,
    I was hoping to ask for advice. I currently own a 1998 Mitsu Lancer. Ok naman siya but I was thinking of buying a second hand car this year. Budget ko is around 300k to 400k. maybe more kung kelangan but not much. I'm torn between 10.5 gen altis and 3rd gen vios, both automatic kasi almost the same price na rin sila. btw, solo lang ako so its either 2 to 4 passengers lang. sa kotse. don't plan to use it much except for out of town trips kasi may may motmot naman ako for nearby errands. thanks
    #3183
    Quote Originally Posted by tikbalang21 View Post
    i wouldn't buy a second car, if i intend to use it sparingly only.
    maintenance and wear and tear, just sitting there in the garage...
    i speak from experience.
    the older altises and the vioses, may look big on the outside, but are really not-that-big, on the inside. try them on for size before plunging.
    Jun 2012
    #3184
    Thanks for the advise ... I'm selling the Lancer and getting another car. So technically, it would be my only car to go out of town or to use it when the weather isn't so good when using a motorcycle. I'll try to look at both the Altis and the Vios as well.
    Feb 2012
    #3185
    I am with dr.d on not having 2 cars if will only be used sparingly.
    I now have a 9th and a 10.5 gen. I try to balance my usage but still, after a year one had just around 3,000 kms. The other one just barely made past 5,000 kms. Yung 5k na-change oil ko na although previously I only do it at 8k+. So yung isa siguro by one more month pa bago mag-OC. Sayang din kasi fully synthetic tapos oversized filter pa. At one time, nasira pa yung battery ko (although 4++ years na rin) since di ko nagamit ng ilang weeks. Then yung bagong battery na-drain din since di ko ulit nagamit ng ilang weeks. So now I made it a point na ma-swap ko sila twice a week.
    About the Vios and the Altis naman, I'd go with the 10.5 gen kung same price as the Vios at good condition naman. Fuel consumption concerns for me is a bit overrated. Drive economically, and you will enjoy the power and roominess of the bigger sedan.
    Jun 2012
    #3186
    Goodpm...Ask lang where maganda magpapalit ng ENGINE SUPPORT and how much kaya aabutin? Corolla Altis 10th gen..thank you...
    #3187
    Quote Originally Posted by Ewric View Post
    yun pinakamalaki na engine support 6.8k, the rest is under 4k each
    sa exalta banawe mura lang labor.
    Jun 2005
    #3188
    Nikko and tenacity are good cheap replacement brands. Used this on a vios and is still good albeit 8 months pa lang.
    Cruven in crame did the replacing. 350 labor per engine mount
    Sent from my MI MAX 2 using Tapatalk
    #3189
    Quote Originally Posted by sirkosero View Post
    makapag testing nga ng nikko
    yun rbi (or another taiwan/china) na ginamit ko sa vios noon, kasi dali mapunit kaya binalik ko nalang orig
    #3190
    loose manual shifter altis corolla 2008 - YouTube
    may nakapag palit na ng shifter bushing ng gen 10?
Toyota Corolla 10th Generation Altis Owners [continued]
