Results 11 to 19 of 19
August 3rd, 2005 06:05 PM #11
Iba yung LC100 and 105 series sa LC90 & LC120. Eto nga pala yung LC website, meron din Hilux models.
click here!
August 3rd, 2005 07:54 PM #12
Originally Posted by naruto
August 4th, 2005 12:19 AM #13
iba talaga ang 1KZ :d dati nakahiram ako ng ex-JDM na LC90 naka 1KZ.. lakas sa hatak grabe parang gas..
August 4th, 2005 12:29 AM #14
[QUOTE]
mas malakas ba ang 1KZ sa 4m41 sir??
August 4th, 2005 01:03 AM #15
Toyota:
1KZ-T 85/3600-kW/rpm 295/2400-Nm/rpm
1KZ-TE 96/3600-kW/rpm 343/2000-Nm/rpm
Mitsubishi:
4M40 289/2000-Nm/rpm
4M41 130/3800-kW/rpm 382/2000-Nm/rpm
Power factors are subject to ratings only, power on wheels depending on gears at transmission, transfer case, differentials & vehicle weight factor.
http://www.sae.org/automag/globalview_01-00/09.htm
http://www.lcool.org/technical/90_se...ets/specs.html
August 4th, 2005 01:08 AM #16
thank you sir ungas!!(parang nakakahiyang tawagin kang sir and ungas) hehehe for the infornative link!
August 4th, 2005 01:13 AM #17Power factors are subject to ratings only, power on wheels depending on gears at transmission, transfer case, differentials & vehicle weight factor.
August 4th, 2005 08:36 AM #19
in terms of 4cylinder diesel, the 4m41 still is the class leading 4 cylinder diesel direct injection engine out there. but all the others are catching up na. d4d of toyota for one will overtake it for sure once toyota modifies more.
Tesla Philippines
