Results 11 to 19 of 19
August 3rd, 2005 06:05 PM #11
Iba yung LC100 and 105 series sa LC90 & LC120. Eto nga pala yung LC website, meron din Hilux models.
click here!
August 3rd, 2005 07:54 PM #12
Originally Posted by naruto
August 4th, 2005 12:19 AM #13
iba talaga ang 1KZ :d dati nakahiram ako ng ex-JDM na LC90 naka 1KZ.. lakas sa hatak grabe parang gas..
August 4th, 2005 12:29 AM #14
[QUOTE]
mas malakas ba ang 1KZ sa 4m41 sir??
August 4th, 2005 01:03 AM #15
Toyota:
1KZ-T 85/3600-kW/rpm 295/2400-Nm/rpm
1KZ-TE 96/3600-kW/rpm 343/2000-Nm/rpm
Mitsubishi:
4M40 289/2000-Nm/rpm
4M41 130/3800-kW/rpm 382/2000-Nm/rpm
Power factors are subject to ratings only, power on wheels depending on gears at transmission, transfer case, differentials & vehicle weight factor.
http://www.sae.org/automag/globalview_01-00/09.htm
http://www.lcool.org/technical/90_se...ets/specs.html
August 4th, 2005 01:08 AM #16
thank you sir ungas!!(parang nakakahiyang tawagin kang sir and ungas) hehehe for the infornative link!
August 4th, 2005 01:13 AM #17Power factors are subject to ratings only, power on wheels depending on gears at transmission, transfer case, differentials & vehicle weight factor.
August 4th, 2005 08:36 AM #19
in terms of 4cylinder diesel, the 4m41 still is the class leading 4 cylinder diesel direct injection engine out there. but all the others are catching up na. d4d of toyota for one will overtake it for sure once toyota modifies more.
