Results 11 to 20 of 30
    Jul 2003
    my wild guess, is your radiator cover needs replacement.
    sir ang nakikita kong leak e doon mismo sa baba ng mga rows sa may cover ng radiator sa baba part nya
    Quote Originally Posted by acenie View Post
    it probably gravitated towards the lower parts, from above.
    you'll just have to see where it is coming from.
    use a strong light source.
    Jul 2003
    ok sir i will check it again, pero sinabi ko na sa mekaniko ko na alisin nalang yung radiator para ma check
    hindi lang powdery sir pag umaga may tumutulo na coolant sa baba nakita ko doon mismo sa pinaka part na mga rows ng radiator sa may cover sa baba
    bro sobrang di halata yan leaks na yan while running or after long cool down. kumbaga sakto moment mo sya makikita, i guess within 30 minutes to an hour after engine is Off.
    from a 30 minute drive ko nakita yun spots.
    eto naman mga leak spots na nakita ko, kaya ko binaklas yun rad.
    eto naman vid nung malakas na leak, even * idle ..
    tiny leak 2 - YouTube
    Aug 2017
    Has anyone tried radiator stop leak products in cases like this? How was it?
    Apr 2010
    Quote Originally Posted by SidCoronel View Post
    Not me but a friend did. It blocked radiator passages when it was opened
    Also do not replace an aluminium/plastic cover with a brass one ("tanso") = galvanic corrosion. i mean it can give you months or years of trouble-free operation but is not the best way to go.
    Aug 2017
    Quote Originally Posted by ParticleX View Post
    Interesting, thanks.
    After how many months after was the radiator opened up?
    Jul 2003
    bumili na ako ng bago radiator. ok lang ba na yung plastic cover na ang ipalit ko kasi yung dati aluminum?
    i suppose so. as long as it fits the space provided.
    an insider once remarked, the reason they manufacture plastic-tubbed radiators, is because they are cheaper to manufacture than metal-tubbed ones.
    if cost is no object, i would do the same.
    Jun 2015
    try mo evercool radiator sir
Hiace Super Grandia 2008 Radiator water Leak..
