Page 4 of 4 FirstFirst 1234
Results 31 to 33 of 33
    May 2009
    #31
    hello po.. need your help! ...
    napansin ko lang po recently na nagkaroon din ako ng similar problem pero hindi ko po alam ang gagawin ko...or ganito din po ba yung naging problem ninyo?
    to start off never ko po ginilaw ung battery ko..pero sa pagkakaalala ko nung nagpa 5k check up ako nag top up ng battery fluid ang TYT Balintawak..then ngayon ko lang po napansin na nagkaroon ng leak..nasa 7k na po ako
    napansin ko din po na natalsikan ung hose na hindi ko po alam ang tawag hehehe
    maraming salamat po in advance...
    andito po yung pictures:
    http://s925.photobucket.com/albums/ad96/caetyryn/
    #32
    As shown in the picture . Try to do it youself .
    1.REmoved the battery.
    2 Get a steel brush and brush the affected area to remove the rust .
    3. Buy an EPOXY Primer and mix with Catalyst and paint the affected area .
    4. Let it dry and put the battery back.
    It looks like theres no need to repair the affected .
    #33
    Quote Originally Posted by speed unlimited View Post
    you might try "turco" to turn rust to iron phosphate before primering.
Help!!! Rust under the hood
