Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
    Feb 2011
    Quote Originally Posted by stormwild View Post
    I'll take a look at the manual.
    may pipindutin ka sa remote ng key para mareprogram yun eh, ang hirap lang intindihin sa manual kase nabasa ko yun dati. innova G/V ba yung sayo? ang panget kase ng tunog eh nu, parang busina. nakarinig ako nun sa fortuner eh, ang sagwa, haha. buti na lang yung saken walang tunog. :D
    Nov 2003
    Where is this? Do you mean inside the car or under the hood?
    Would you have a picture of which wire that would be?
    Yes under the hood, look for something that looks like a small megaphone and just disconnect the harness.
    well, i had something less intrusive and more refundable in mind, but yes, your method is effective.
    It won't void your warranty, no wire cutting, there is a harness.
    Jun 2012
    When I use the key to remotely lock the Toyota Innova there is a loud beep. How do I disable this sound?
    Would really appreciate help on how disable the beep when I remotely lock the door.
    I did not disable the sound but only muffed it such that I can barely hear it. There's a screw on the beeper that I turned to changed the sound. I can show pics if anybody wants
    Jan 2009
    Just for future reference, the procedure to mute or un-mute the arm/disarm answer-back beep is shown in the video below. I've tried it on my 2015 Innova 2.5 G successfully. No need to remove the buzzer harness or mess around with the screw. You don't want to disable the actual buzzer as it's also the same horn that will remind you when you press the lock/arm button on the remote while any of the doors are still open.
    Jun 2007
    Yung sa CRV ko naman lagyan ng tunog. Ang hirap kasi malaman kung nag lolock siya or hindi. Kailangan mo pang tingnan yung ilaw. Pag naikawang ng konti yung pinto ng salisi gang di na siya mag lolock. Maganda yung katulad sa Ford na silent ang lock at unlock pero pag twice mo press yung lock button bubusina siya to confirm na naka lock.
    Jul 2018
    doesnt work on 2018 innova g, does anyone know how to enable the sound? thanks in advance
    Jan 2008
    Quote Originally Posted by n0kn0k View Post
    Hindi na yata OEM toyota yung alarm ng innova.. parang AVT na din yan supplied by winterpine
    Jan 2009
    Of course it won’t work on the 2nd gen Innova. The instructions (and video) are obviously specific to the 1st gen.
Disable the beep sound of the innova when being remotely locked or unlocked
