Page 16 of 27 FirstFirst ... 612131415161718192026 ... LastLast
Results 151 to 160 of 262
    Apr 2005
    #151
    Toyota has been studying the Hybrid system for a very long time. This should make buyers comfortable with their products new tech.
    #152
    Quote Originally Posted by 17Sphynx17 View Post
    EDIT: I came across a website that does mention Hilux having a max payload of only 470kgs but other sites mention around 900~1000kgs payload capacity.
    Ah I get it now. Probably varies between models, and mostly comes down to the difference between curb and gross weights.
    The Hilux that can take 1000kg payload is probably the single cab long bed 2wd only version. The crew cab 4wd is the one with just 470kg payload.
    Dec 2019
    #153
    The Prius has been around since late 1997. With studies and development started in late 80's to early 90's. This is a very good benchmark for their hybrid systems. For me its long been proven.
    Jul 2013
    #154
    Quote Originally Posted by cityfolk View Post
    Very little info has been published about the hybrid drive train of the Zenix. From the wiki page the Zenix apparently has NiMH batteries instead of Lithium. A bit disappointing but it is fit for the purpose. The choice of NiMH most likely driven by the need to keep the cost of the vehicle within a target range.
    10 THINGS YOU PROBABLY DON'T KNOW ABOUT TOYOTA INNOVA ZENIX 2023 PHILIPPINES
    REAL RYAN
    #155
    Toyota Hilux specifications | TrucksBuses.com.
    I am curious about the Hilux they mention though with only 470kg rated payload capacity. It is a dual cab and a 4x4 in this link above. but when you check the publication from ph
    https://phil kotse.com/market-news/w...-capacity-6853
    same dual cab config but I think this conquest trim they mention is a 4x2, it is rated at 1,115kgs
    below is another source stating the same approx 1 ton payload capacity for a single cab
    Specifications for Toyota Hilux Single Cab AN1?/AN2?/AN3?
    So no idea if the limitation of 470kgs payload comes from Toyota themselves, or perhaps how it was registered in India only? Coz I don't think the 4x4 components would be 500kgs total causing the payload to be so low. Or maybe India limits it for pickups there maybe? hehe!
    EDIT: but going back to the Zenix, still haven't seen it in the metal but it is interesting.
    I wonder if they plan on releasing a model in the future where it doesn't have the motorized captain chairs for the second row and the more "typical" 60:40 split bench for the 2nd row?
    Jul 2013
    #156
    2023 Toyota Zenix Hybrid first drive: More than just a hybrid Innova | Top Gear Philippines
    Jul 2013
    #157
    sa wakas, nakakita rin ako ng Zenix sa kalsada
    (2 straight days, 1 in BGC and another in Makati)
    looks way better compared to the 1st 2 generations ng Innova.
    #158
    looks very good. sayang, they did not make a diesel version.
    #159
    Quote Originally Posted by moneyp View Post
    "kkags got to them."
    seriously,
    probably a decision from above, to mirror the needs of the target population.
    there's no need now to make diesel version kasi meron na gas hybrid
2023 Toyota Innova (3rd Gen)
