Results 5,281 to 5,286 of 5286
- Oct 2020
- 6
November 14th, 2020 03:43 PM #5281
- Oct 2020
- 6
November 14th, 2020 03:52 PM #5282Another question po, does the GD series Fortuners have an engine coolant bleeder valve? I can remember our old Innova the gas variant do have one engine coolant bleeder valve near the engine block, just curious if our Fortuner also have one, as it helps to drain some coolant inside the engine as well as to bleed the air out easily.
- Oct 2020
- 6
November 14th, 2020 03:53 PM #5283Another question po, does the GD series Fortuners have an engine coolant bleeder valve? I can remember our old Innova the gas variant do have one engine coolant bleeder valve near the engine block, just curious if our diesel Fortuners also have one, as it helps to drain some coolant inside the engine as well as to bleed the air out easily.
November 14th, 2020 06:32 PM #5284
- 107
February 28th, 2021 12:49 AM #5285will this fit on a stock height: EPISODE – MOD Wheels ?
will this rub on a full turn. at an angle, like on a ramp?
specs:
17×8.5 6H 139.7
+15
i plan to use my stock tires (265/65 r17), and keep it on 17s in the future, when i replace my tires.
thanks!
- 107
April 26th, 2021 12:48 PM #5286Update: Went with the TRD Sema Pro 17s (copy/replica) instead, to maintain the Toyota theme.
