Page 529 of 529 FirstFirst ... 429479519525526527528529
Results 5,281 to 5,286 of 5286
    Oct 2020
    #5281
    parang mas mura parin OEM eh 400 plus sa casa 2 liters
    tama rin Sir, I do get the point, better stick with OEM coolant na lang kung mas mura pa.
    Oct 2020
    #5282
    Another question po, does the GD series Fortuners have an engine coolant bleeder valve? I can remember our old Innova the gas variant do have one engine coolant bleeder valve near the engine block, just curious if our Fortuner also have one, as it helps to drain some coolant inside the engine as well as to bleed the air out easily.
    Oct 2020
    #5283
    Another question po, does the GD series Fortuners have an engine coolant bleeder valve? I can remember our old Innova the gas variant do have one engine coolant bleeder valve near the engine block, just curious if our diesel Fortuners also have one, as it helps to drain some coolant inside the engine as well as to bleed the air out easily.
    these aftermarket choices are more expensive. even the ATF ? hahahha
    #5285
    will this fit on a stock height: EPISODE – MOD Wheels ?
    will this rub on a full turn. at an angle, like on a ramp?
    specs:
    17×8.5 6H 139.7
    +15
    i plan to use my stock tires (265/65 r17), and keep it on 17s in the future, when i replace my tires.
    thanks!
    #5286
    Update: Went with the TRD Sema Pro 17s (copy/replica) instead, to maintain the Toyota theme.
2016 Toyota Fortuner
