Results 31 to 40 of 106
February 19th, 2008 08:46 PM #31
eto naman tanung ko for the owners with automatic headlights:
paano gumagana yun, pati yung kung may DRL din....
February 19th, 2008 10:16 PM #32
Nagaala "DRL" ako (turning manually my headlight on hindi lang park lights), ala DRL kasi walang DRL installed ang sasakyan ko starting at 5pm (may araw man or makulimlim na), pag nasa tunnel, pag nasa covered parking at pag umuulan.
Peeps you should turn on your headlights not just your parking lights inside covered parking lots kasi sa tahimik ng mga makina ngayon doon lang makikita ng pedestrian kung may paparating na sasakyan. Muntik na akong masagasaan nyan dati kasi itong ogag na driver hindi naka turn on ang headlights, mayron pa naman written rule na pag magpapark sa basement ng office namin dapat naka turn on ang headlights.Last edited by froshie1; February 19th, 2008 at 10:21 PM.
February 20th, 2008 09:35 AM #33
I also think that a lot of people confuse their park lights or even the low-beam lights with daytime running lights.
With your park lights, a peanut bulb in front & your rear lamps are on.
With you low-beam lights, the peanut bulb, low-beam lamp & rear lamps are on.
With daytime running lights, it uses either a park light or a low-watt (around 20W) forward light (and not the low-beam) and there is no rear light on.
Here's the problem with using your park / low-beam lights as a pseudo-DRL:
1. Your rear lamps stay on... if you don't have a 3rd brake lamp or have a relatively weak taillamp or have an el-cheapo LED taillamp (like the one used in the Corolla) - other drivers will have a hard time distinguishing if you're braking or not.
2. As mentioned by mbiege, the instrument cluster also gets light. This is no problem if you have an light output adjuster (like in the Rav) or have an optitron gauge - but the vehicles equipped with these are in minority.
3. You produce unnecessary glare and distraction if you insist on using your low-beam headlamps... that is why other drivers are signaling / flashing you. That's why DRLs have half the output of regular low-beam lamps.
Hopefully this clarifies the confusion with using DRLs since most vehicles being sold here in the Philippines are not equipped with the said feature.
If you still insist on using your park/low-beam lights as a pseudo-DRL device...
February 20th, 2008 09:56 AM #34
- Sep 2007
- 150
February 20th, 2008 12:12 PM #35
- Sep 2007
- 150
February 20th, 2008 01:22 PM #36may nakasalubong na din akong cadillac escalade dati equipped w/ DRL dito lang sa antips
- Jan 2007
- 2,452
February 20th, 2008 01:38 PM #37
Tsikot Member Rank 4
- 2,719
February 20th, 2008 02:15 PM #38some have their sensors on the rearview mirror mount assembly
the automatic mode can be turned-off, i.e., manual control as usual ... some defaults to automatic mode when car starts
same can be said of those having automatic wipers ... with rain sensor at the windshield
February 20th, 2008 03:00 PM #39
February 20th, 2008 04:07 PM #40
Tesla Philippines
