Results 2,171 to 2,180 of 2668
- Apr 2015
- 3
April 23rd, 2015 09:25 AM #2171Sir nagka problima din po ba ang ignition system bakit pinalitan? Ask ko lang po sir kasi nasira ang ignition switch ng APV ko baka may luma ka dyang pwedeng bilhin! APV -2 GLX po ang ride ko 2010
- Apr 2015
- 3
April 23rd, 2015 09:30 AM #2172Its 44 psi pag loaded sir pero pag normal lang 30 sa harap and 35 sa likod.
- Apr 2015
- 3
April 23rd, 2015 09:42 AM #2173Go lang ng Go APV! Sa ibang site sabi ng iba d daw maganda ang APV pero para sa akin na dalawang APV na ang nabili, maling mali cla. Sasakyan ito masisira din tulad ng iba depende lang talaga sa pag gamit at saan gagamitin.
- 53,883
April 23rd, 2015 10:02 AM #2174it's probably easier to swap that chair with the company car's, and re-upholster it, compared to having to look for a surplus unit..
you can also ask the casa.. they might charge you two arms and a leg, but at least, it's brand new.. but if it's covered with vinyl also, heh vheh...
BANNED BANNED BANNED
- 126
April 23rd, 2015 12:52 PM #2175That's an option. As per your suggestion, that would mean that the "skeleton/frame" of the benches (vinyl, or the foam one) are identical, and it would just be the upholstery that is different? Kasi, baka naman mas maganda talaga yung "innards" ng 2nd row bench na hindi vinyl...
Thanks!
- 126
April 25th, 2015 02:10 PM #2176[cross posted in another sub-forum]
Switched from "passenger tires" to "light truck tires". Same size (185 R14).
Question, do I use the same tire pressures as on the "passenger tires" now that I have "light duty truck/van" tires?
FWIW, vehicle is Suzuki APV. Recommended tire pressures are 29 front, 35 rear; 32 front, 44 rear if fully laden.
Reason I ask is the guys at Goodyear (I got Cargo G26 tires) pumped the rear to 50 psi.
- 126
April 25th, 2015 06:28 PM #2177Sino meron APV carry or Panel Van (where the original equipment tires are the LT-rated tires -- 185R14C)?
Ano nakasulat na tire pressures doon sa door jamb? (yung sticker)? Thanks!
- Jul 2011
- 81
- Jul 2011
- 81
April 29th, 2015 02:39 PM #2179Tanong lang din uli mga peeps,
Paano kaya malalagyan ng Aux yung HU. Old style pa kasi yung nakalagay sakin and may cassette tape player pa.
TIA
TIA
- Jun 2012
- 4,447
April 29th, 2015 06:06 PM #2180Yung ipapasok na casette pero may wire na pang aux. Di ko lang alam saan makabili
Tesla Philippines
